#1 2016-03-12 14:03
ThisGuy1996
Changing the login background wallpaper
For months, I've been searching to change the default login background wallpaper, but to no avail. But last night, I discovered that the solution was so simple. Later today I will post a tutorial.
#2 2016-03-12 17:31
bobby
Re: Changing the login background wallpaper
@ThisGuy1996,
I have been wanting to do this as well. Please do share, can't wait - Thanks smile
Bobby
No Longer Using Q4OS
#3 2016-03-12 20:48
ThisGuy1996
Go to start menu--->Settings -----> Control Panel ---->  System Administration -----> Login Manager ---> Under the "background tab, select the background image of your choice.
#4 2016-03-12 22:54
bobby
@ThisGuy1996,
I don't have a "Login Manager" icon on my " TDE Control Panel.
Do I need to turn that on some how or can it be launched using | Menu --> Run Command ?
Thanks,
Bobby
#5 2016-03-12 23:17
ThisGuy1996
Did you go through System Administration?
Could you post a picture?
#6 2016-03-12 23:41
I think you have installed TDE modules that are not shipped with q4os by the looks of things.
#7 2016-03-12 23:49
Nothing wrong with adding to q4os, it just won't be available to everyone. I will look into changing q4os login when I have a few minutes smile
#8 2016-03-13 00:01
ThisGuy1996
I had to change the background because It hurt my eyes. Plus, I have OCD
#9 2016-03-13 00:09
ThisGuy1996
I couldn’t help it. I wanted to make it look more like Xp. I changed the desktop appearance, and thought it would be cool to change it.
#10 2016-03-13 00:15
ThisGuy1996
No big deal, I joke about it all the time.
#11 2016-03-13 00:19
ThisGuy1996
I pay too much attention to little details. Changing the login background made my day.
#12 2016-03-13 00:46
I found the setting, it is in the file /etc/trinity/tdm/backgroundrc you will need to be root to edit but you can if you want (just right click -> actions -> edit as root), and change "Wallpaper[$e]=/opt/trinity/share/wallpapers/q4os-wp01.png" to your choice. Just be careful what you change smile
#13 2016-03-13 02:50
bobby
Hey,  lets skip the chit-chat (just kidding), I still don't know how to add that Administrator Icon to Control Panel sad Please tell me, I'm really want to know.
#14 2016-03-13 02:55
bobby
@Dai,
Thanks for sharing file and location to switch Login Background.  Diving in as root, wish me luck smile
Bobby
#15 2016-03-13 03:08
ThisGuy1996
$ sudo kcmodules --unlock should do the trick.
#16 2016-03-13 03:17
bobby
Thanks - that's right. Now I remember. Q4OS member originally posted that (link below) info but, slipped by me what it was for.
http://www.q4os.org/forum/viewtopic.php?pid=1732#p1732
Now Changing Login Wallpaper and unlocking kcmodules smile
Thanks So Much !
Bobby
#17 2016-03-13 04:52
bobby
@ThisGuy1996,
I now have access to Login Screen Administration configuration.
Thanks,
Bobby
#18 2016-03-13 09:56
Just had a look at that command and it unlocks a few things:- thememanager style, icons, kmlaunch, ksplashmanager, twindecorarion and tdm, so should give you everything needed to make your screen "pretty" smile
#19 2016-03-13 18:09
bobby
I wonder if these modules are locked out by default in TDE or a Q4OS build decision.
I am very thankful to have access to all these new settings.  I have fully customized my system, logos, icons, backgrounds, wallpaper
Thanks Guys smile
Bobby
#20 2016-03-13 18:20
I'm similar, I tend to test (and break) systems regularly, but usually stick to offered theme and change the background to something more pleasing to me.
#21 2016-03-13 18:41
I must admit I have had a few systems go rotten on me, but usually can recover them, although nowadays it's quicker and easier to just reinstall than it is to fix systems.
#22 2016-03-14 06:56
ThisGuy1996
This is a dumb question, but how does one break a distro?
#23 2016-03-14 07:18
bobby
Let a noobie answer this.  One wrong " in the wrong place and your system could stop working smile  Okay, its not quite that bad.
Making unrecommended changes to a system like the wrong path in TDE or installing a non-compatible package to your system could break it. Non-compatible packages are built for other distros that do not follow Debian's packagement management schema, like Ubuntu packages.  Anytime you install a package it has to be a Debian Jessie package deb (for Q4OS v1.x) and correct cpu architecture too 32bit / x64.  There are checks in apt-get / dpkg / gdebi and Synaptic to prevent using the wrong package.
Making direct code changes to system files could also break your distro (system).
granting yourself root access and rename a system folder or file to other than normal could break your Distro.
I break Distros all the time.  I have 9 hard dirves with major modded Q4OS Installs.  I call them Q4 because when I am done hacking them they don't usually act like an OS smile
#24 2016-03-14 18:16
ThisGuy1996
Quick question...do you know what a Konquisidebar is?
#25 2016-03-14 18:40
If I were to hazard a guess it would be something like an interactive sidebar for konqueror, but only a guess. smile
