#1 2023-06-30 14:16
vanquishedangel
Intel Turbo Cache (robson)
Hi, and thank you.
I know this is possibly farfetched as Robson was a failed tertiary technology. I also researched it a lot and there is not much information on it but there does seem to be a partial driver for the chip for linux. I also know that my case/request maybe specific and will not apply to a majority of people.
But I was hoping that since q4os was built to be lightweight and work on aging hardware, that maybe it could be incorporated into the kernel (if it is not already) or have a/the driver incorporated and that it could serve its use.
I fixed up an old dell d430 and while it actually works great (thanks to q4os and a ton of tweaks), it has the ability to use the Robson chip. Since the hard drive connector is the old apple ziff connector, its speed it limited to 80mbps despite it now having an SSD. The Robson chip could be really helpful in this case.
This could be added on the side through q4os repositories. Also having such a driver or ability to use a space as hard drive cache (different then swap) may be beneficial in the future anyway as technology improves and speeds get faster (you can add a faster chip then the hard drive to boost the computer). Similar to ready boost etc.
One of the partial drivers: https://github.com/yarrick/turbomem
I have also read up on EnhanceIO, zfs, and Bcache.
#2 2023-07-07 03:37
vanquishedangel
Re: Intel Turbo Cache (robson)
So I received my Robson chip today and put it in the computer, I have some tests for you guys smile. this was just after physically installing it. The odd part is it is not listed in lspci that I can see, but appears to be seen as a USB connected device.
I think it is seen as "Bus 005 Device 003: ID 0e39:a100 Smart Modular Technologies, Inc. Dell ON Storage"
shawn@shawn-latituded430:~$ sudo hdparm -Tt /dev/sda
/dev/sdb (robson Chip):
Timing cached reads: 1396 MB in 2.00 seconds = 698.05 MB/sec
Timing buffered disk reads: 56 MB in 3.05 seconds = 18.39 MB/sec
/dev/sda (main Hard drive SSD with a pata connection):
Timing cached reads: 1408 MB in 2.00 seconds = 704.35 MB/sec
Timing buffered disk reads: 252 MB in 3.02 seconds = 83.52 MB/sec
shawn@shawn-latituded430:~$ sudo hdparm -Tt /dev/sdc
/dev/sdc (swap space 2gig amtron PCMCIA card):
Timing cached reads: 2 MB in 2.32 seconds = 882.25 kB/sec
Timing buffered disk reads: 4 MB in 4.65 seconds = 879.92 kB/sec
output of lsusb:
Bus 005 Device 004: ID 0e39:a100 Smart Modular Technologies, Inc. Dell ON Storage
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0e39 Smart Modular Technologies, Inc.
  idProduct          0xa100
  bcdDevice           15.00
  iManufacturer           1 SMART
  iProduct                2 Dell ON Storage
  iSerial                 3 2011030599180364
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0020
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Bus 005 Device 002: ID 413c:a005 Dell Computer Corp. Internal 2.0 Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x413c Dell Computer Corp.
  idProduct          0xa005 Internal 2.0 Hub
  bcdDevice           50.18
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0029
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
So the odd parts are i did not install any software, The chip is not made by intel but by Dell and Smart, even though it was labeled "intel Robson". Either way it appears to be working and can be seen in gparted and smartctl. Some things are boosted on the dell latitude d430 like loading the ram disk when booting and applications do appear to be faster and smoother.
This device appears as a block device as well, it may be possible to use it for swap.
#3 2023-07-07 14:13
vanquishedangel
Also to note, though the speeds seem to read at the same rate between the hard drive and the "robson" chip, originally the highest speed hdparm reported (before installing the robson chip) was 85 mbps. After installing that chip it says over 700mbps.
But it also seems the feature has been added either in the kernel, or computer bios already.
#4 2023-07-28 17:36
As far as I know, Q4OS Team does not make customized Linux kernels. They use standard Debian Linux kernels. Maybe, you could contact Debian Linux developers?
