#1 2021-09-29 21:02
calebs
problem with gemini and libmysql
Hello all, thanks for this magnificent linux distro i like a lot and i'm installing into a lot of machines and recommending to a lot of people.
I have a problem with the recently launched gemini x64 trinity.
When i try to install default-libmysqlclient-dev came with an error saying that some packages are not created or came from incoming.
libssl-dev depends libssl1.1 (= 1.1.1.1k-1) but (1.1.1k-1+deb11u1 wil be installed
and can't advance from there.
it's almost default installation with live iso trinity and it's up to date with apt.
thanks!
btw, with previous version it worked out of the box
#2 2021-09-29 21:18
Re: problem with gemini and libmysql
Did you run
$ sudo apt update
$ sudo apt dist-upgrade
before the "default-libmysqlclient-dev" installation ?
#3 2021-09-29 21:42
calebs
Yes, this problem is from a couple days ago, i have installed in a proxmox vm... i've waited a couple of days, then today apt update and apt upgrade and apt dist upgrade but the error persists
