#1 2020-04-30 20:16
javgar
Pin application to the bar
Hello
I can't pin my app on the bar once opened
or am I wrong ?!
Regards
#2 2020-04-30 20:23
Re: Pin application to the bar
What desktop environment do you use ?
#3 2020-04-30 21:10
javgar
Hello
Trinity with windows 10 downloaded from xpq4.sourceforge.io/
#4 2020-04-30 21:14
Unfortunately, Trinity desktop doesn't support to pin applications on the panel. You would need to use Plasma desktop for that.
