I am creating a tutorial for installing all three profiles on a hard drive in own partition.
sda1 = pure install
sda2 = basic profile
sda3 = desktop profie
Is there a way to display the hostname automatically in TDE control bar or on desktop ?
or can this be done with a bash script in Autoload menu ?
If not, I would just make some cool wallpager that shows the matching profile name that they a user can install to same profile configuration.
These wallpaper can be branded with links to Q4OS Homepage | Q4OS Forum | Q4OS Learning Portal (My Site) & a Donate Link for "Please Support Q4OS Development"
Thanks,
Bobby
No Longer Using Q4OS
I have my hostname shown on my desktop using conky as you can (almost) see on my screenshot shown here https://www.q4os.org/forum/viewtopic.php?pid=651#p651
In case you can't see it I located it at the top of the screen just above the Remote Ip on the connections info (blurred out for privacy).
It's not on the menubar, but it is a great way to have all sorts of info on your desktop.
Dai
Da, Thank You... Trying Conky right now.
