#1 2017-09-10 04:00
sergioandvar
Flatpak & Snappy packaging support
Is it possible that you can add Flatpak/Snappy out of the box in Q4OS? I'd like to install this kind of packages that can be upgraded easily. Is it too difficult to make it a default in a fresh installation?
Thanks for your time.
Q4OS Colombian User
#2 2017-09-11 12:26
Re: Flatpak & Snappy packaging support
Q4OS Scorpion supports Flatpak/Snappy out of the box. Q4OS Orion stable doesn't support it and there is no plan to add this feature in.
#3 2017-09-12 04:03
sergioandvar
It's a great notice. Updated apps on a solid base operating system like Debian make a great combination!
Q4OS Colombian User
#4 2017-09-21 00:50
Just curious sergioandvar, what do you like about flatpack/snappy packaging?
#5 2017-09-22 00:48
sergioandvar
Well, I like the chance to have some applications updated on a stable environment. Something I like about rolling release distros is that you can have your apps updated. In this case We could have updated applications on stable environments. On the other hand, could be easier to get some applications that don't belong to the Debian repositories.
Q4OS Colombian User
#6 2017-09-23 17:32
I use many distros not just Q4OS and using the typical package managers I have few issues with getting updated apps. I see this new method has more flexibility overall but trying to understand what many see in this update design.
#7 2018-05-11 19:04
Some applications like newest Skype run well only in Flatpak packaging environment. Also You will not damage your main system if something will go wrong with them as they work separately in their environment (isolated).
