#1 2016-05-22 15:29
Q4os-devpack for Scorpion
Will there be a dev-pack installer for Scorpion in the near future? I did try the current installer and it failed which wasn't much of a surprise as the dependencies would probably need to be changed. Just something on my wish-list really smile
#2 2016-05-22 18:29
Re: Q4os-devpack for Scorpion
The installer for Scorpion will be released later, unfortunately. Nonetheless, we have attached a 'blank' installer with no dependencies, you can install them manually. Please keep in mind, it is not an official installer, use it on your own.
http://www.q4os.org/setup_q4os-devpack_ … nk_all.esh
#3 2016-05-22 20:53
Many thanks, I have installed a few "essentails" already and can use this to get what else I need. smile
#4 2016-08-25 09:22
Just re-installed Scorpion and tried the download link in post #2 but it does not exist any more, should I just use the normal dev-pack installer now?
#5 2016-08-25 10:03
Link activated. You could try to install DevPack using normal installer first.
#6 2016-08-25 10:07
Thanks, I will download and try normal installer first and post back if any problems. smile
EDIT: Failed to install the normal installer with
Simulation not successful, sorry, I cannot install now.
Cleaning and canceling ...
Output from installer is
Calculating progress ...
Testing Internet connection ...
Testing Internet connection ... OK
Extracting archive ...
Extracting archive ... Done
Checking package system ...
Reading package lists... 100%
Reading package lists... Done
Building dependency tree... 50%
Verified ... OK
Autofix not needed ... OK
Waiting to complete current operation ... Done
Adding security keys ...
Adding security keys ... OK
Preparing installation files ...
Preparing installation files ... OK
Partial update sw database ...
Partial update sw database ... Done
Testing installation ...
Reading state information... 0%
Testing installation ... Done
Update sw database ...
0% [Working]
Ign:1 copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ InRelease
0% [Working]
Ign:2 copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ Release
0% [Working]
Ign:3 copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ Packages
0% [Working]
Ign:4 copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ Translation-en_GB
0% [Working]
Ign:5 copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ Translation-en
0% [Working]
Ign:6 copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ Translation-en_GB.UTF-8
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
0% [Working]
Get:3 copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ Packages [719 B]
0% [3 Packages 0 B/719 B 0%]
0% [Working]
0% [Connecting to www.deb-multimedia.org]
0% [3 Packages store 0 B] [Connecting to www.deb-multimedia.org]
0% [Connecting to www.deb-multimedia.org (91.121.10.104)]
Hit:7 http://www.deb-multimedia.org stretch InRelease
0% [Connecting to q4os.org] [Connecting to security.debian.org]
0% [7 InRelease gpgv 31.5 kB] [Connecting to q4os.org (81.95.96.231)] [Connecti
Hit:8 http://ftp.debian.org/debian stretch InRelease
0% [7 InRelease gpgv 31.5 kB] [Waiting for headers] [Waiting for headers] [Conn
Hit:9 http://ftp.debian.org/debian stretch-updates InRelease
0% [7 InRelease gpgv 31.5 kB] [Waiting for headers] [Connecting to security.deb
Hit:10 http://q4os.org/q4repo q4os-1-0-cn InRelease
Hit:11 http://q4os.org/q4repo q4os-2-0-cn InRelease
Hit:12 http://security.debian.org stretch/updates InRelease
Hit:13 http://q4os.org/qtderepo jessie InRelease
0% [Waiting for headers]
0% [8 InRelease gpgv 251 kB] [Waiting for headers]
Hit:14 http://q4os.org/qtderepo stretch InRelease
0% [Working]
0% [9 InRelease gpgv 124 kB]
0% [Working]
0% [10 InRelease gpgv 3,931 B]
0% [Working]
0% [11 InRelease gpgv 3,913 B]
0% [Working]
0% [12 InRelease gpgv 68.2 kB]
0% [Working]
0% [13 InRelease gpgv 3,940 B]
0% [Working]
0% [14 InRelease gpgv 3,883 B]
100% [Working]
Fetched 719 B in 1s (602 B/s)
Reading package lists... 99%
Update sw database ... Done
N: Can't drop privileges for downloading as file '/tmp/tmp.8l7Y0wfPNg-q4appsetup/tmp-setup-repo/InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
W: The repository 'copy:/tmp/tmp.8l7Y0wfPNg-q4appsetup tmp-setup-repo/ Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
q4os-devpack : Depends: tqt3-designer but it is not going to be installed
Depends: libtqtinterface-dev but it is not going to be installed
Depends: tdelibs-trinity-dev
Depends: tqt3-linguist but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I ran "apt-get update" and "apt-get dist-upgrade" afterwards and although there were no packages to update I received no error warnings so will try the alternative installer.
#7 2016-08-30 18:18
olzeke51
moved to new topic - Gary Olzeke51
Dev Pack 1.61 Orion - missing doc
The journey is . . . the reward.
#8 2016-08-30 19:04
Hi Gary, To create a new post in the forum just select the category you want and then click the "post new topic" at the top of the page smile
I can't really make much sense of what you have done, that is I cannot say what you have installed so it would be very difficult to say what the actual problem is or what the solution would be...
if you want to create a fresh topic please state the version of Q4OS you are using
get-q4os-version
and we would need to know what package you installed and/or where it came from. If it is a .esh installer then it is likely to have been created for q4os as I don't know any other OS that uses them (although I don't use ALL linux distro's so could be wrong).
#9 2016-08-30 20:56
olzeke51
#10 2016-08-30 20:59
olzeke51
