#1 2016-03-05 20:05
Changing font size
How to change application font size in VLC Media Player and Synaptic Package manager? Editing ~/.gtkrc-q4os and ~/.gtkrc-q4os-kde4 does not help.
Shotwell also refuses to change font size.
#2 2016-03-06 21:22
Re: Changing font size
VLC Player and QT4 apps fonts:
Install 'qt4-qtconfig' package:
$ sudo apt-get install qt4-qtconfig
run:
$ qtconfig-qt4
update settings for QT4 applications
or manually edit '$HOME/.config/Trolltech.conf' file.
GTK applications:
Edit '~/.gtkrc-q4os' file.
#3 2016-03-07 14:07
Thank you! Partially this helped. Unfortunately Synaptic Package manager and Nautilus still have small default 9 font.
#4 2016-03-07 14:19
Edit '/root/.gtkrc-q4os' and '/root/.config/gtk-3.0/settings.ini' files to change Synaptic font, as it's ran with root uid.
For GTK3 applications like Nautilus you have to edit '$HOME/.config/gtk-3.0/settings.ini' file
#5 2016-03-07 17:02
Yes! Finally all fonts are correct!
