#1 2023-08-21 19:56
WDS
Wine_Classic theme still needs work
The Wine_Classic theme still has two major flaws:
(1) When a wallpaper is selected, the desktop icons have opaque blue boxes around their filenames. Those blue boxes should be transparent.
(2) There is a gap between the Start menu and the taskbar, and a gap between the Start menu an the left edge of the screen. These gaps should not exist; the Start menu should be perfectly aligned with both the taskbar and the left edge of the screen.
#2 2023-08-21 22:48
WDS
Re: Wine_Classic theme still needs work
Comparison between real Windows Classic theme and Q4OS version. Problem areas are indicated in yellow:
#3 2023-10-28 23:19
NTNozomu
Those boxes are actually a thing on Windows 9x and 2000, the transparency didn't become a thing until XP, and even then, if XP was set to "best performance", it will generate those backgrounds.
