#1 2023-09-05 16:28
WinREAgent
Trinity Desktop Enviroment doesn't work
Hi,
I've installed Q4OS 4.12 i386 on my HP Pavillion ze4300 to give it a new life, but from the very first boot TDE has never start and the PC has only the command line interface. I tried to use the startx command to launch TDE, but when I use the command a black screen appear. The mouse is the only thing that works, but the rest of the PC freeze and I have to disconnect the power to reset it.
I checked .xinitrc and there's just a line with
/etc/X11/Xsession
but the Xsession file did not contain any reference to inittde file (which I assume serves to start TDE), and I was unable to find TDE itself. So I installed it using
sudo apt install tde-trinity
sudo apt install tde-i18n-it-trinity
and then I changed .xinitrc by deleting the old line and adding
exec /opt/trinity/bin/starttde
After that, when I use startx, the screen turns blue and the cursor appears, but I get an error message saying "Could not start tdeinit. Please check your installation." with an ok button that takes me back to the terminal. I have googled a lot but I can't find anything about this problem. Please help me, it's my first time with Linux.
Xorg.0.log file:
[    93.748]
X.Org X Server 1.20.11
X Protocol Version 11, Revision 0
[    93.748] Build Operating System: linux Debian
[    93.748] Current Operating System: Linux q4os-desktop 5.10.0-25-686-pae #1 SMP Debian 5.10.191-1 (2023-08-16) i686
[    93.749] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-25-686-pae root=UUID=33e36926-b4e6-45ce-9ec7-ef0fbaee9b87 ro quiet loglevel=3 systemd.log_color=0 systemd.show_status=1
[    93.749] Build Date: 23 March 2023  10:25:56AM
[    93.749] xorg-server 2:1.20.11-1+deb11u6
[    93.749] Current version of pixman: 0.40.0
[    93.749]     Before reporting problems, check
    to make sure that you have the latest version.
[    93.749] Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    93.749] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Sep  5 11:55:38 2023
[    93.965] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    93.965] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    94.626] (==) No Layout section.  Using the first Screen section.
[    94.626] (==) No screen section available. Using defaults.
[    94.626] (**) |-->Screen "Default Screen Section" (0)
[    94.626] (**) |   |-->Monitor "<default monitor>"
[    94.663] (==) No monitor specified for screen "Default Screen Section".
    Using a default monitor configuration.
[    94.663] (==) Automatically adding devices
[    94.664] (==) Automatically enabling devices
[    94.664] (==) Automatically adding GPU devices
[    94.664] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    95.229] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[    95.229]     Entry deleted from font path.
[    95.229] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    95.229] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    95.229] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    95.230] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    95.230]     Entry deleted from font path.
[    95.230] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    95.230] (==) FontPath set to:
    /usr/share/fonts/X11/Type1,
    built-ins
[    95.230] (==) ModulePath set to "/usr/lib/xorg/modules"
[    95.230] (II) The server relies on udev to provide the list of input devices.
    If no devices become available, reconfigure udev or disable AutoAddDevices.
[    95.230] (II) Loader magic: 0x759740
[    95.230] (II) Module ABI versions:
[    95.230]     X.Org ANSI C Emulation: 0.4
[    95.230]     X.Org Video Driver: 24.1
[    95.230]     X.Org XInput driver : 24.1
[    95.230]     X.Org Server Extension : 10.0
[    95.238] (++) using VT number 7
[    95.238] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    95.242] (II) xfree86: Adding drm device (/dev/dri/card0)
[    95.250] (--) PCI:*(1@0:5:0) 1002:4336:103c:0024 rev 0, Mem @ 0xe0000000/268435456, 0xd0100000/65536, I/O @ 0x00009000/256, BIOS @ 0x????????/131072
[    95.300] (II) LoadModule: "glx"
[    95.417] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    96.246] (II) Module glx: vendor="X.Org Foundation"
[    96.246]     compiled for 1.20.11, module version = 1.0.0
[    96.246]     ABI class: X.Org Server Extension, version 10.0
[    96.246] (II) Applying OutputClass "Radeon" to /dev/dri/card0
[    96.246]     loading driver: radeon
[    96.246] (==) Matched radeon as autoconfigured driver 0
[    96.247] (==) Matched ati as autoconfigured driver 1
[    96.247] (==) Matched modesetting as autoconfigured driver 2
[    96.247] (==) Matched fbdev as autoconfigured driver 3
[    96.247] (==) Matched vesa as autoconfigured driver 4
[    96.247] (==) Assigned the driver to the xf86ConfigLayout
[    96.247] (II) LoadModule: "radeon"
[    96.247] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[    97.074] (II) Module radeon: vendor="X.Org Foundation"
[    97.074]     compiled for 1.20.9, module version = 19.1.0
[    97.074]     Module class: X.Org Video Driver
[    97.074]     ABI class: X.Org Video Driver, version 24.1
[    97.075] (II) LoadModule: "ati"
[    97.075] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    97.128] (II) Module ati: vendor="X.Org Foundation"
[    97.129]     compiled for 1.20.9, module version = 19.1.0
[    97.129]     Module class: X.Org Video Driver
[    97.129]     ABI class: X.Org Video Driver, version 24.1
[    97.281] (II) LoadModule: "modesetting"
[    97.282] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    97.475] (II) Module modesetting: vendor="X.Org Foundation"
[    97.475]     compiled for 1.20.11, module version = 1.20.11
[    97.475]     Module class: X.Org Video Driver
[    97.475]     ABI class: X.Org Video Driver, version 24.1
[    97.475] (II) LoadModule: "fbdev"
[    97.475] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    97.603] (II) Module fbdev: vendor="X.Org Foundation"
[    97.603]     compiled for 1.20.0, module version = 0.5.0
[    97.603]     Module class: X.Org Video Driver
[    97.603]     ABI class: X.Org Video Driver, version 24.0
[    97.603] (II) LoadModule: "vesa"
[    97.603] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    97.659] (II) Module vesa: vendor="X.Org Foundation"
[    97.659]     compiled for 1.20.9, module version = 2.5.0
[    97.659]     Module class: X.Org Video Driver
[    97.659]     ABI class: X.Org Video Driver, version 24.1
[    97.659] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
    ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
    ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
    ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
    ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
    ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
    ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
    ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
    ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
    ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
    ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
    ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
    ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
    ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
    ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
    ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
    ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
    ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
    ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
    ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
    ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
    ATI Radeon 9800PRO, ATI Radeon 9800XT,
    ATI Radeon Mobility 9600/9700 (M10/M11),
    ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
    ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
    ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
    ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
    ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
    ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
    ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
    ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
    ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
    ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
    ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
    ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
    ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
    ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
    ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
    ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
    ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
    ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
    ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
    ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
    ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
    ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
    ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
    ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
    ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
    ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
    ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
    ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
    ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
    ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
    ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
    ATI FireGL V3350, ATI Mobility Radeon X1450,
    ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
    ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
    ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
    ATI FireGL V3400, ATI Mobility FireGL V5250,
    ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
    ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
    ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
    ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
    ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
    ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
    ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
    ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
    ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
    ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
    ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
    ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
    AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
    ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
    ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
    ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
    ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
    ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
    ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
    ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
    ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
    ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
    ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
    ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
    ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
    ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
    ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
    ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
    ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
    ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
    ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
    ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
    ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
    ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
    ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
    ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
    ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
    ATI FireGL V3600, ATI Radeon HD 2600 LE,
    ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
    ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
    ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
    ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
    ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
    ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
    ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
    ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
    ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
    ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
    ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
    AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
    AMD Radeon HD 6300 Series Graphics,
    AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
    ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
    AMD Firestream 9350, ATI Radeon HD 5800 Series,
    ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
    ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
    ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
    ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
    REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
    ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
    AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
    AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
    ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
    MULLINS, KAVERI, HAWAII
[    97.670] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    97.670] (II) FBDEV: driver for framebuffer: fbdev
[    97.670] (II) VESA: driver for VESA chipsets: vesa
[    97.693] (II) [KMS] Kernel modesetting enabled.
[    97.693] (WW) Falling back to old probe method for modesetting
[    97.694] (WW) Falling back to old probe method for fbdev
[    97.694] (II) Loading sub module "fbdevhw"
[    97.694] (II) LoadModule: "fbdevhw"
[    97.827] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    97.847] (II) Module fbdevhw: vendor="X.Org Foundation"
[    97.847]     compiled for 1.20.11, module version = 0.0.2
[    97.847]     ABI class: X.Org Video Driver, version 24.1
[    98.120] (II) RADEON(0): Creating default Display subsection in Screen section
    "Default Screen Section" for depth/fbbpp 24/32
[    98.120] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[    98.121] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    98.121] (==) RADEON(0): Default visual is TrueColor
[    98.121] (==) RADEON(0): RGB weight 888
[    98.121] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[    98.121] (--) RADEON(0): Chipset: "ATI Radeon IGP320M (U1)" (ChipID = 0x4336)
[    98.121] (II) Loading sub module "fb"
[    98.121] (II) LoadModule: "fb"
[    98.122] (II) Loading /usr/lib/xorg/modules/libfb.so
[    98.230] (II) Module fb: vendor="X.Org Foundation"
[    98.230]     compiled for 1.20.11, module version = 1.0.0
[    98.230]     ABI class: X.Org ANSI C Emulation, version 0.4
[    98.230] (II) RADEON(0): GPU accel disabled or not working, using shadowfb for KMS
[    98.230] (II) Loading sub module "shadow"
[    98.230] (II) LoadModule: "shadow"
[    98.230] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    98.312] (II) Module shadow: vendor="X.Org Foundation"
[    98.315]     compiled for 1.20.11, module version = 1.1.0
[    98.315]     ABI class: X.Org ANSI C Emulation, version 0.4
[    98.315] (II) RADEON(0): KMS Color Tiling: disabled
[    98.315] (II) RADEON(0): KMS Color Tiling 2D: disabled
[    98.315] (II) RADEON(0): KMS Pageflipping: enabled
[    98.315] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[    98.615] (II) RADEON(0): Output VGA-0 has no monitor section
[    98.617] (II) RADEON(0): Output LVDS has no monitor section
[    98.622] (II) RADEON(0): Output S-video has no monitor section
[    98.622] (WW) RADEON(0): 3 ZaphodHeads crtcs unavailable. Some outputs will stay off.
[    98.653] (II) RADEON(0): EDID for output VGA-0
[    98.653] (II) RADEON(0): EDID for output LVDS
[    98.653] (II) RADEON(0): Manufacturer: LGP  Model: 6e54  Serial#: 0
[    98.653] (II) RADEON(0): Year: 1990  Week: 0
[    98.653] (II) RADEON(0): EDID Version: 1.3
[    98.653] (II) RADEON(0): Digital Display Input
[    98.653] (II) RADEON(0): Max Image Size [cm]: horiz.: 30  vert.: 22
[    98.654] (II) RADEON(0): Gamma: 2.20
[    98.654] (II) RADEON(0): DPMS capabilities: Off
[    98.654] (II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    98.654] (II) RADEON(0): First detailed timing not preferred mode in violation of standard!
[    98.654] (II) RADEON(0): redX: 0.565 redY: 0.332   greenX: 0.313 greenY: 0.534
[    98.654] (II) RADEON(0): blueX: 0.157 blueY: 0.140   whiteX: 0.313 whiteY: 0.328
[    98.654] (II) RADEON(0): Manufacturer's mask: 0
[    98.654] (II) RADEON(0): Supported detailed timing:
[    98.654] (II) RADEON(0): clock: 65.0 MHz   Image Size:  304 x 228 mm
[    98.654] (II) RADEON(0): h_active: 1024  h_sync: 1048  h_sync_end 1696 h_blank_end 1344 h_border: 0
[    98.654] (II) RADEON(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 806 v_border: 0
[    98.654] (II) RADEON(0): EDID (in hex):
[    98.654] (II) RADEON(0):     00ffffffffffff0030f0546e00000000
[    98.654] (II) RADEON(0):     00000103801e167828c7749055508828
[    98.654] (II) RADEON(0):     23505400000001010101010101010101
[    98.654] (II) RADEON(0):     01010101010164190040410026301888
[    98.654] (II) RADEON(0):     362030e4100000180000000000000000
[    98.654] (II) RADEON(0):     00000000000000000000000000000000
[    98.654] (II) RADEON(0):     0000000000000000000000000000004f
[    98.655] (II) RADEON(0): Printing probed modes for output LVDS
[    98.655] (II) RADEON(0): Modeline "1024x768"x47.5   65.00  1024 1048 1696 1697  768 771 777 806 -hsync -vsync (38.3 kHz e)
[    98.655] (II) RADEON(0): Modeline "800x600"x60.0   38.31  800 832 912 1024  600 603 607 624 -hsync +vsync (37.4 kHz)
[    98.655] (II) RADEON(0): Modeline "848x480"x59.9   31.65  848 872 952 1056  480 483 493 500 -hsync +vsync (30.0 kHz)
[    98.655] (II) RADEON(0): Modeline "720x480"x59.9   26.85  720 744 808 896  480 483 493 500 -hsync +vsync (30.0 kHz)
[    98.655] (II) RADEON(0): Modeline "640x480"x59.9   23.98  640 664 720 800  480 483 487 500 -hsync +vsync (30.0 kHz)
[    98.660] (II) RADEON(0): EDID for output S-video
[    98.660] (II) RADEON(0): Output VGA-0 disconnected
[    98.660] (II) RADEON(0): Output LVDS connected
[    98.660] (II) RADEON(0): Output S-video disconnected
[    98.660] (II) RADEON(0): Using exact sizes for initial modes
[    98.660] (II) RADEON(0): Output LVDS using initial mode 1024x768 +0+0
[    98.660] (II) RADEON(0): mem size init: gart size :20000000 vram size: s:8000000 visible:7cc0000
[    98.660] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[    98.660] (==) RADEON(0): DPI set to (96, 96)
[    98.660] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
[    98.660] (II) Loading sub module "ramdac"
[    98.660] (II) LoadModule: "ramdac"
[    98.660] (II) Module "ramdac" already built-in
[    98.660] (II) UnloadModule: "modesetting"
[    98.660] (II) Unloading modesetting
[    98.661] (II) UnloadModule: "fbdev"
[    98.661] (II) Unloading fbdev
[    98.661] (II) UnloadSubModule: "fbdevhw"
[    98.661] (II) Unloading fbdevhw
[    98.661] (II) UnloadModule: "vesa"
[    98.661] (II) Unloading vesa
[    99.000] (II) RADEON(0): Front buffer size: 3072K
[    99.000] (II) RADEON(0): VRAM usage limit set to 112176K
[    99.092] (==) RADEON(0): DRI3 disabled
[    99.093] (==) RADEON(0): Backing store enabled
[    99.093] (WW) RADEON(0): Direct rendering disabled
[    99.093] (II) RADEON(0): Acceleration disabled
[    99.093] (==) RADEON(0): DPMS enabled
[    99.093] (==) RADEON(0): Silken mouse enabled
[    99.221] (II) Initializing extension Generic Event Extension
[    99.222] (II) Initializing extension SHAPE
[    99.223] (II) Initializing extension MIT-SHM
[    99.228] (II) Initializing extension XInputExtension
[    99.270] (II) Initializing extension XTEST
[    99.271] (II) Initializing extension BIG-REQUESTS
[    99.272] (II) Initializing extension SYNC
[    99.273] (II) Initializing extension XKEYBOARD
[    99.273] (II) Initializing extension XC-MISC
[    99.274] (II) Initializing extension SECURITY
[    99.274] (II) Initializing extension XFIXES
[    99.275] (II) Initializing extension RENDER
[    99.275] (II) Initializing extension RANDR
[    99.280] (II) Initializing extension COMPOSITE
[    99.281] (II) Initializing extension DAMAGE
[    99.281] (II) Initializing extension MIT-SCREEN-SAVER
[    99.282] (II) Initializing extension DOUBLE-BUFFER
[    99.282] (II) Initializing extension RECORD
[    99.283] (II) Initializing extension DPMS
[    99.283] (II) Initializing extension Present
[    99.286] (II) Initializing extension DRI3
[    99.286] (II) Initializing extension X-Resource
[    99.286] (II) Initializing extension XVideo
[    99.287] (II) Initializing extension XVideo-MotionCompensation
[    99.287] (II) Initializing extension SELinux
[    99.287] (II) SELinux: Disabled on system
[    99.287] (II) Initializing extension GLX
[    99.481] (II) AIGLX: Screen 0 is not DRI2 capable
[   115.228] (II) IGLX: Loaded and initialized swrast
[   115.228] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[   115.228] (II) Initializing extension XFree86-VidModeExtension
[   115.229] (II) Initializing extension XFree86-DGA
[   115.230] (II) Initializing extension XFree86-DRI
[   115.230] (II) Initializing extension DRI2
[   115.232] (II) RADEON(0): Setting screen physical size to 270 x 203
[   115.727] (II) config/udev: Adding input device Power Button (/dev/input/event8)
[   115.727] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   115.728] (II) LoadModule: "libinput"
[   115.728] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   115.810] (II) Module libinput: vendor="X.Org Foundation"
[   115.810]     compiled for 1.20.8, module version = 0.30.0
[   115.810]     Module class: X.Org XInput Driver
[   115.810]     ABI class: X.Org XInput driver, version 24.1
[   115.810] (II) Using input driver 'libinput' for 'Power Button'
[   115.810] (**) Power Button: always reports core events
[   115.810] (**) Option "Device" "/dev/input/event8"
[   115.811] (**) Option "_source" "server/udev"
[   115.860] (II) event8  - Power Button: is tagged by udev as: Keyboard
[   115.860] (II) event8  - Power Button: device is a keyboard
[   115.861] (II) event8  - Power Button: device removed
[   115.862] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input9/event8"
[   115.862] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   115.862] (**) Option "xkb_layout" "it"
[   115.919] (II) event8  - Power Button: is tagged by udev as: Keyboard
[   115.919] (II) event8  - Power Button: device is a keyboard
[   115.922] (II) config/udev: Adding input device Video Bus (/dev/input/event1)
[   115.922] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   115.922] (II) Using input driver 'libinput' for 'Video Bus'
[   115.922] (**) Video Bus: always reports core events
[   115.922] (**) Option "Device" "/dev/input/event1"
[   115.922] (**) Option "_source" "server/udev"
[   115.926] (II) event1  - Video Bus: is tagged by udev as: Keyboard
[   115.927] (II) event1  - Video Bus: device is a keyboard
[   115.927] (II) event1  - Video Bus: device removed
[   115.927] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:00/LNXVIDEO:00/input/input2/event1"
[   115.927] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   115.927] (**) Option "xkb_layout" "it"
[   115.933] (II) event1  - Video Bus: is tagged by udev as: Keyboard
[   115.933] (II) event1  - Video Bus: device is a keyboard
[   115.935] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[   115.935] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   115.935] (II) Using input driver 'libinput' for 'Power Button'
[   115.935] (**) Power Button: always reports core events
[   115.935] (**) Option "Device" "/dev/input/event6"
[   115.935] (**) Option "_source" "server/udev"
[   115.939] (II) event6  - Power Button: is tagged by udev as: Keyboard
[   115.939] (II) event6  - Power Button: device is a keyboard
[   115.939] (II) event6  - Power Button: device removed
[   115.939] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7/event6"
[   115.939] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[   115.939] (**) Option "xkb_layout" "it"
[   115.943] (II) event6  - Power Button: is tagged by udev as: Keyboard
[   115.944] (II) event6  - Power Button: device is a keyboard
[   115.946] (II) config/udev: Adding input device Lid Switch (/dev/input/event7)
[   115.946] (II) No input driver specified, ignoring this device.
[   115.946] (II) This device may have been added with another device file.
[   115.950] (II) config/udev: Adding input device USB USB Keyboard (/dev/input/event3)
[   115.950] (**) USB USB Keyboard: Applying InputClass "libinput keyboard catchall"
[   115.950] (II) Using input driver 'libinput' for 'USB USB Keyboard'
[   115.950] (**) USB USB Keyboard: always reports core events
[   115.950] (**) Option "Device" "/dev/input/event3"
[   115.950] (**) Option "_source" "server/udev"
[   115.956] (II) event3  - USB USB Keyboard: is tagged by udev as: Keyboard
[   115.956] (II) event3  - USB USB Keyboard: device is a keyboard
[   115.957] (II) event3  - USB USB Keyboard: device removed
[   115.957] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb1/1-1/1-1:1.0/0003:1A2C:2D23.0001/input/input4/event3"
[   115.957] (II) XINPUT: Adding extended input device "USB USB Keyboard" (type: KEYBOARD, id 9)
[   115.957] (**) Option "xkb_layout" "it"
[   115.964] (II) event3  - USB USB Keyboard: is tagged by udev as: Keyboard
[   115.964] (II) event3  - USB USB Keyboard: device is a keyboard
[   115.968] (II) config/udev: Adding input device USB USB Keyboard Consumer Control (/dev/input/event4)
[   115.968] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[   115.968] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[   115.968] (**) USB USB Keyboard Consumer Control: always reports core events
[   115.968] (**) Option "Device" "/dev/input/event4"
[   115.968] (**) Option "_source" "server/udev"
[   115.974] (II) event4  - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[   115.975] (II) event4  - USB USB Keyboard Consumer Control: device is a keyboard
[   115.975] (II) event4  - USB USB Keyboard Consumer Control: device removed
[   115.975] (II) libinput: USB USB Keyboard Consumer Control: needs a virtual subdevice
[   115.975] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb1/1-1/1-1:1.1/0003:1A2C:2D23.0002/input/input5/event4"
[   115.976] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: MOUSE, id 10)
[   115.976] (**) Option "AccelerationScheme" "none"
[   115.976] (**) USB USB Keyboard Consumer Control: (accel) selected scheme none/0
[   115.976] (**) USB USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[   115.976] (**) USB USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[   115.982] (II) event4  - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[   115.983] (II) event4  - USB USB Keyboard Consumer Control: device is a keyboard
[   115.986] (II) config/udev: Adding input device USB USB Keyboard System Control (/dev/input/event5)
[   115.986] (**) USB USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[   115.986] (II) Using input driver 'libinput' for 'USB USB Keyboard System Control'
[   115.986] (**) USB USB Keyboard System Control: always reports core events
[   115.986] (**) Option "Device" "/dev/input/event5"
[   115.986] (**) Option "_source" "server/udev"
[   115.992] (II) event5  - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[   115.993] (II) event5  - USB USB Keyboard System Control: device is a keyboard
[   115.993] (II) event5  - USB USB Keyboard System Control: device removed
[   115.993] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb1/1-1/1-1:1.1/0003:1A2C:2D23.0002/input/input6/event5"
[   115.994] (II) XINPUT: Adding extended input device "USB USB Keyboard System Control" (type: KEYBOARD, id 11)
[   115.994] (**) Option "xkb_layout" "it"
[   116.000] (II) event5  - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[   116.001] (II) event5  - USB USB Keyboard System Control: device is a keyboard
[   116.003] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[   116.003] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   116.003] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   116.003] (**) AT Translated Set 2 keyboard: always reports core events
[   116.004] (**) Option "Device" "/dev/input/event0"
[   116.004] (**) Option "_source" "server/udev"
[   116.008] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   116.008] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[   116.010] (II) event0  - AT Translated Set 2 keyboard: device removed
[   116.010] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[   116.010] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[   116.010] (**) Option "xkb_layout" "it"
[   116.015] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   116.015] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[   116.020] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event2)
[   116.020] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[   116.020] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[   116.020] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[   116.020] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Touchpad"
[   116.020] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[   116.020] (**) SynPS/2 Synaptics TouchPad: always reports core events
[   116.020] (**) Option "Device" "/dev/input/event2"
[   116.020] (**) Option "_source" "server/udev"
[   116.024] (II) event2  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   116.030] (II) event2  - SynPS/2 Synaptics TouchPad: device is a touchpad
[   116.030] (II) event2  - SynPS/2 Synaptics TouchPad: device removed
[   116.030] (**) Option "Tapping" "true"
[   116.031] (**) Option "ScrollMethod" "edge"
[   116.031] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input3/event2"
[   116.031] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[   116.033] (**) Option "AccelerationScheme" "none"
[   116.033] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[   116.033] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[   116.033] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[   116.037] (II) event2  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   116.041] (II) event2  - SynPS/2 Synaptics TouchPad: device is a touchpad
[   116.044] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[   116.044] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[   116.045] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[   116.045] (II) No input driver specified, ignoring this device.
[   116.045] (II) This device may have been added with another device file.
[   116.065] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[   116.065] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[   116.065] (**) USB USB Keyboard Consumer Control: always reports core events
[   116.065] (**) Option "Device" "/dev/input/event4"
[   116.065] (**) Option "_source" "_driver/libinput"
[   116.065] (II) libinput: USB USB Keyboard Consumer Control: is a virtual subdevice
[   116.065] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb1/1-1/1-1:1.1/0003:1A2C:2D23.0002/input/input5/event4"
[   116.065] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: KEYBOARD, id 14)
[   116.065] (**) Option "xkb_layout" "it"
[   125.782] (II) event8  - Power Button: device removed
[   125.782] (II) event1  - Video Bus: device removed
[   125.783] (II) event6  - Power Button: device removed
[   125.783] (II) event3  - USB USB Keyboard: device removed
[   125.783] (II) event5  - USB USB Keyboard System Control: device removed
[   125.787] (II) event0  - AT Translated Set 2 keyboard: device removed
[   125.788] (II) event2  - SynPS/2 Synaptics TouchPad: device removed
[   125.789] (II) event4  - USB USB Keyboard Consumer Control: device removed
[   125.792] (II) UnloadModule: "libinput"
[   125.793] (II) UnloadModule: "libinput"
[   125.797] (II) UnloadModule: "libinput"
[   125.883] (II) Server terminated successfully (0). Closing log file.
tdm.log file:
Sep  5 11:55:33 tdm_config[586] info: Cannot open master configuration file /etc/trinity/tdm/tdmdistrc
Sep  5 11:56:10 tdm: :0[890] error: Abnormal termination of greeter for display :0, code 0, signal 7
P.S. Sorry for my english, I'm not a native speaker
#2 2023-09-05 16:40
Re: Trinity Desktop Enviroment doesn't work
What way did you install Q4OS 4 and why didn't you use the more recent Q4OS 5 images ?
#3 2023-09-05 17:00
WinREAgent
My PC only support boot from CD, that can fit 700 MB. This is smaller than the Q4OS 5 iso size, so I used a version that can stay in 700 MB of space (Q4OS Gemini, Trinity, 32bit). I burned the cd with CDBurnerXP at x48 speed. I used the full automated install and nothing gone wrong during the installation
#4 2023-09-05 17:19
Try to reboot, login to console and run:
$ sudo systemctl restart tdm.service
and post back
#5 2023-09-05 17:37
WinREAgent
and post back
When I run the command the screen turns black and a loading cursor appears, but after a few seconds it takes me back to the console
#6 2023-09-05 18:07
It looks your hardware is not compatible with Q4OS. You could still install plain Debian and then use a dedicated script to install Q4OS on top of Debian, see https://q4os.org/dqa017.html . You can report a hardware related bug at Q4OS bug tracker https://sourceforge.net/p/q4os/tickets
