#1 2023-08-14 02:57
capytalist
Devuan support for q4os-setup.sh
When will we get Devuan support back into Q4OS - I tried to use q4os-setup.sh but it wouldn't work, I had to install lsb, and then it said Devuan wasn't supported, it would be great if Q4OS had support for no systemd distros, since trinity does work splendidly on Runit, in fact, you can run trinity on BSD no problem whatsoever. It'd be great for folks who like true UNIX systems, since Dragora is not the most stable yet and getting in touch with the devs or getting started isn't that easy
#2 2023-08-14 12:18
Re: Devuan support for q4os-setup.sh
Yes, it is planned to be available until end of this year,
#3 2023-08-15 11:05
Just my follow-up post, please ignore. neutral
#4 2023-08-18 01:06
capytalist
Okay thanks for all the hard work, the OS is rock solid!
#5 2023-09-03 20:49
New version of q4os-setup script that includes support for Devuan Daedalus is available for download, Documentation https://www.q4os.org/dqa017.html
