#1 2023-05-03 10:48
Q4OS Gemini 4.12
An update to Q4OS 4 Gemini stable has been released, version 4.12, see announcement https://www.q4os.org/blog.html#news230503 and tweet https://twitter.com/q4osteam/status/165 … 45344?s=20
#2 2023-05-04 20:17
fred
Re: Q4OS Gemini 4.12
hii,
Thank you for this new version.
However, I updated to version 4.12, but still under debian 11.6.
uname -r
6.1.0-0.deb11.6-amd64
cat /proc/version
Linux version 6.1.0-0.deb11.6-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP PREEMPT_DYNAMIC Debian 6.1.15-1~bpo11+1 (2023-03-16)
et
get-q4os-version
4.12.1-n1
Did I miss something?
Thx
F
#3 2023-05-04 21:09
The default kernel version for Debian 11.7 is 5.10.0-22 . You are using some non standard kernel.
#4 2023-05-05 09:42
fred
yes ok, thanks for your answer
I had upgraded to the latest kernel available to make my wifi connection more stable, for the driver RTL8821CE 802.11ac PCIe Wireless Network Adapter
using :
sudo qinst-kernel-bpo
seen here : https://www.q4os.org/forum/viewtopic.php?id=4423
it won't be too much of a problem for future updates?
F
#5 2023-05-05 09:54
It shouldn't be a problem, however we recommend to use the default Debian kernel, see https://www.q4os.org/dqa011.html#system.6
#6 2023-05-05 10:10
fred
Yes, okay. I will still be able to boot with the old kernel if a problem occurs
thank you for everything
F
