#1 2021-08-25 11:23
labppaua
SAMBA speed
I ask for help. SAMBA speed problem. When uploading less than 10 times. On the same computer but with a different OS, everything is fine. The problem is only in q4os, and only through samba. how to setup ? what is the problem?
#2 2021-08-25 15:13
Re: SAMBA speed
What are the symptoms? Can you show your /etc/samba/smb.conf file? Just omit whatever private info you may have there, i.e. ip addresses.
#3 2021-08-26 06:05
Re: SAMBA speed
smb4k was always the tool I used to use to configure smb in a windows network.
#4 2021-08-31 09:52
labppaua
Re: SAMBA speed
channel speed 100 mb. In Windows OS or in Ubuntu on the same computer with default settings, the speed is 100 mb.
In q4os, only 10 mb. Poor speed only with samba resources. there are no problems with nfs or ftp, there is 100mb.
default configuration file, I have not changed the settings
[global]
;   interfaces = 127.0.0.0/8 eth0
;   bind interfaces only = yes
   log file = /var/log/samba/log.%m
   max log size = 1000
   logging = file
   panic action = /usr/share/samba/panic-action %d
   server role = standalone server
   obey pam restrictions = yes
   unix password sync = yes
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
   pam password change = yes
   map to guest = bad user
;   logon path = \\%N\profiles\%U
;   logon drive = H:
;   logon script = logon.cmd
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
; add group script = /usr/sbin/addgroup --force-badname %g
;   include = /home/samba/etc/smb.conf.%m
;   idmap config * :              backend = tdb
;   idmap config * :              range   = 3000-7999
;   idmap config YOURDOMAINHERE : backend = tdb
;   idmap config YOURDOMAINHERE : range   = 100000-999999
;   template shell = /bin/bash
   usershare allow guests = yes
[homes]
   comment = Home Directories
   browseable = no
   read only = yes
   create mask = 0700
   directory mask = 0700
   valid users = %S
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   read only = yes
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
;   directory mask = 0700
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
;   write list = root, @lpadmin
#5 2021-09-12 09:06
labppaua
Re: SAMBA speed
Hi. There is no solution to my question?
