#1 2021-07-28 15:43
Pen95
Login issue
I have been using q4os for a while, but 2 days ago something strange has been happening.
When i logged in, it turned to a black screen for 3 seconds, then brung me to a login screen. I tried some commands, and now it says "please check if dcopserver is running."
can you please help me fix this?
#2 2021-07-30 12:57
Re: Login issue
Please login to the console and run commands to update:
$ sudo apt update
$ sudo apt dist-upgrade
reboot, and post back the result. We would also need more detailed info about your system, see https://www.q4os.org/forum/viewtopic.php?id=3502
