#1 2021-05-27 22:09
sub13
LibreOffice .doc
Bonjour
Est Il possible avec Writer de LibreOffice d'avoir directement l'extension .doc qui s'ajoute au nom des fichier quad on enregistre au format word97-2003.
Je ne trouve pas le réglage dans outils puis option puis chargement/enregistrement.
merci
Hello
Is it possible with LibreOffice Writer to directly have the .doc extension which is added to the name of the quad files we save in word97-2003 format.
I cannot find the setting in tools then option then load / save.
thank you
Asus Eee PC 1000H Atom N270 à 1.6 GHz ram 2go avec Q4os 3.16.1 centaurus
#2 2021-05-27 22:37
Re: LibreOffice .doc
Are you asking how to make this the default? You can try in Tools > Options > Open/Save > General and  look for the option Always Save as  expand the drop-down menu and select the desired format you'd like to save your files with.
NOTE: I'm using the latest version of LibreOffice suite, 7.1.3 and not sure if a previous one has it too, but I kind of remember that it does.
#3 2021-05-27 22:42
sub13
Ok thanks qI have sent word as default format, but I have to add .Doc at thé end of the name. I don't find the option for to add this automatiquely.
Bye thank you
#4 2021-05-27 23:09
I'm sorry, but I'm not sure I understand what you're asking, however, if your question is how to save files with .doc as the extension when using Save as, you can do so by expanding the drop-down menu in the save dialog box, as shown in the screenshot
#5 2021-05-27 23:13
sub13
Yes it is ok thanks you.
Good night
#6 2021-05-28 07:44
sub13
Hello
just to show you that on windows 10 LibreOffice 7, I have "add automatic file name extension box" but not on LibreOffice 6 Linux as you can see in the screen view;
Thank you
#7 2021-07-12 14:50
The Save dialog I get with LibreOffice 6.1.5.2 / Q4OS / Plasma is very different from the screen capture you provided. Mine is hereunder and the checkbox for auto extension is well present.
Can you provide us with a screenshot of the About window from your version of LibreOffice?
#8 2021-07-12 15:07
He's using Trinity, not Plasma. I don't know exactly how different this kind of(libre office)dialogs can be(I use Plasma too) though.
#9 2021-08-15 01:03
DavidB
I don't know if I'm helping at all, it's been a while since this question was posted, but here where I can set the default "Save As" setting in my LibreOffice on my Trinity desktop:
It's under Options > Load/Save > General
Does this help at all?
