#1 2021-01-28 19:19
barquest
Alternate file managers
I do not like the default file manager, so I installed some others.
Cinnamon's Nemo is usually a great file manager, as it has all user folders on the left side. But not on Trinity, which only has user, desktop, and trash. Thunar has the same problem, but I cannot remember if it is better on Xfce systems. Is this configurable?
I installed Dolphin, but when I started it, I saw an error dialog with the message "There are two actions (New Tab, New Tab) that want to use the same shortcut (Ctrl+T). This is most probably a bug. Please report it in bugs.kde.org." Is this a Trinity bug or a KDE bug?
#2 2021-01-29 06:23
Re: Alternate file managers
You haven't said which version of Q4OS you've installed. The following applies to TDE
For Thunar you need a file  ~/.configtde/gtk-3.0/bookmarks
file:///home/your-user-name/Documents
file:///home/your-user-name/Downloads
file:///home/your-user-name/Music
file:///home/your-user-name/Pictures
file:///home/your-user-name/Videos
#3 2021-01-30 21:35
barquest
Sorry, I did neglect to mention the installed version. I downloaded and installed "Q4OS Centaurus, Trinity, install-cd - 64bit / x64 ... 464 MBytes." I chose the middle option of features. I chose Trinity (TDE) over KDE Plasma.
Thanks for the configuration details. Thunar is a good file manager.
#4 2021-02-02 22:46
cpcnw
Quite like this one;
http://roland65.free.fr
#5 2021-02-11 22:31
barquest
@bin
I tried the bookmarks file you suggested. All of the entries appear after the standard (I'm doing this from memory): user, Desktop, Trash. In other words, if I create a bookmarks file that includes an entry for Desktop, I'll end up with two entries for Desktop in the left menu. There must be a bookmarks file somewhere in /usr/share (or something like that) that includes the standard entries. Do you know the location of that bookmarks file?
#6 2021-02-12 07:05
The bookmarks file you create needs only the entries that are not already there.
In the left hand pane in Thunar there are 3 sections - Devices, Places, Network.
Right click on any one of those words and a selection menu pops out to allow you to enable or disable individual items.
I do not recommend you use that to switch off one of your Desktop entries - get the bookmarks file correct as I showed above.
