I tried following this from the FAQ:
"You need to add an application shortcut, i.e. the '.desktop' file, into the '$HOME/.trinity/Autostart' or '$HOME/.q4data/Programs/Startup' autostart folder.
I am using the MATE desktop environment.
I put two of my .desktop files, conky.desktop and anydesk.desktop, in BOTH of those folders.
But when I login to MATE again, those programs don't start.
What am I doing wrong?
This procedure is applicable for Trinity desktop only. We would recommend you to add application shortcuts into the '$HOME/.config/autostart' folder to autostart applications for Mate as well as other XDG complying desktop environments.
Thank you, Q4OS Team.
I had to create the $HOME/.config/autostart folder befor moving the .desktop files into it.
But it worked.
But it worked.
This does not work under Trinity - it's just the other way round.
If you use Trinity, you will have to use
When using different desktop environments,
may or may not work.
Kind regards,
DAC324
In addition
$HOME/.configtde/autostart/
would be the proper alternative auto-start folder in Q4OS.
I have tried to get Onboard virt. keyboard pop up at login with these methods on my tablet pc. These only work after login. How can I manage to have a keyboard at login screen? Any more suggestions? thanks
I use Q4OS 3.13.1 with Plasma. I found that I had to put my .desktop files into
$HOME/.configkde/autostart
I have also other existing autostart folders
$HOME/.configlxqt/autostart
I guess they are specific for LXQT and TDE except that, for TDE, q4odteam has mentioned
Indeed, with Plasma, nothing autostarted from
Moreover, if I put a .desktop file there, Dolphin displays its icon with an exclamation mark in a small orange square superimposed. This probably indicates a problem, but I have no idea of what the problem is, except that Dolphin might be clever enough to detect that this .desktop file is in an inappropriate folder; is it?
A few weeks ago, a new .desktop file for MEGAsync still appeared there automatically (with the exclamation mark), maybe after an automatic update of megasync... Any suggestion of what I should do with this new file? Overwrite the one in the "kde" autostart folder?
What about System Settings > Startup and Shutdown > Autostart ? Then just hit Add Program or Add Script navigate to the executable/binary/script's location, select it, click on apply and that's it. This in Plasma, don't know about TDE, but it works for me just fine. I haven't used Mate in a very long time, but this article explains how to do what you want to
https://www.addictivetips.com/ubuntu-li … uge%20list.
