#1 2021-01-10 23:44
johnp
Warpinator
Hello, Is it possible to install "Warpinator" on TDE?..I searched in Synaptic Package Manager but nothing came up, Thanks
"john@john-pc:~$ sudo apt-get install warpinator
Reading package lists... Done
Building dependency tree
E: Unable to locate package warpinator
john@john-pc:~$"
https://www.omgubuntu.co.uk/2020/03/lin … nding-tool
#2 2021-01-16 21:48
Re: Warpinator
I am afraid, now it is not possible, since this application was developed for Linux Mint. https://github.com/linuxmint/warpinator
You can try to build it by yourself, but there is no warranty, that it will run.
Also, you can ask Q4OSTeam, to make it available in Q4OS Software centre, but still it will require testing, testing and testing...
#3 2021-01-17 05:39
johnp
Re: Warpinator
Thanks Rademes....I used to use "Giver" a long time ago...(https://www.addictivetips.com/ubuntu-linux-tips/giver-makes-transfer-of-files-easier-on-a-linux-network/)
After Giver died off (which I'm not sure why) I went to Dukto (https://www.msec.it/blog/dukto/)...but its not being maintaned anymore.
I have a desktop and this laptop that i share files with and Dukto worked great.Just wish I could find another simple GUI file transfer tool.
#4 2021-01-17 10:13
Re: Warpinator
Hi johnp,
Warpinator seems to be available as flatpak on flathub.
#5 2021-01-17 14:31
johnp
Re: Warpinator
Hello hchiper and thanks for info....Im not very familiar with flatpak...would it work ok on TDE?
#6 2021-01-17 20:02
Re: Warpinator
I havent used Flatpak with Debian or Q4OS but Debian does support Flatpak.
https://flatpak.org/setup/Debian/
#7 2021-01-18 03:54
johnp
Re: Warpinator
Thanks crosscourt for the link.I may give Flatpak a try.
#8 2021-01-18 17:31
Re: Warpinator
smile
