#1 2020-12-14 13:57
elektron
dolphin 20 root
how can i run as root?
#2 2020-12-14 17:29
wove
Re: dolphin 20 root
Open it from the command line with "sudo dolphin"
bill
#3 2020-12-14 17:41
elektron
Re: dolphin 20 root
no no. not possibile.
#4 2020-12-14 22:53
Re: dolphin 20 root
sudo is for running terminal applications as superuser.
If you want to run graphical application in Trinity desktop environment, you should type Alt+F2, then tdesudo dolphin.
#5 2020-12-15 11:58
elektron
Re: dolphin 20 root
i am using kde plasma desktop. (q4os 4.1) dolphin not runing on root. why? double commander does.
#6 2020-12-15 13:07
Re: dolphin 20 root
KDE policy. Neither will Kate nor any other KDE program; they just won't.  It's a KDE thing. If you want/need to run some app in KDE on root, do it like this:
pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY KDE_SESSION_VERSION=5 KDE_FULL_SESSION=true dolphin
Copy/paste that in konsole, press enter and voilà! Change dolphin to use it with other app, i.e. Kate.
You could also put that in a script:
#!/bin/bash
xdotool windowminimize $(xdotool getactivewindow) #to minimize konsole once the rooted app starts.
pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY KDE_SESSION_VERSION=5 KDE_FULL_SESSION=true $1 #"$1"=app name
name that something like run_as_root.sh, give it executable permissions
chmod +x run_as_root.sh
and launch the app you want to launch as root like:
$ ./run_as_root.sh dolphin
Hope this helps! smile
#7 2020-12-15 17:08
elektron
Re: dolphin 20 root
not working. only user mode.
"Executing Dolphin with sudo is not possible due to unfixable security vulnerabilities."
i dont understand.
#8 2020-12-15 17:37
Re: dolphin 20 root
There is an interesting article about this: https://phabricator.kde.org/R40:9adcebd … 46b0e12a7e
KDE security team member thinks, that running GUI applications as root is a huge security risk. Especially the X server is not secured for that.
#9 2020-12-15 18:01
Re: dolphin 20 root
i dont understand.
It works for me
I get the password dialog box
and a rooted-dolphin window is launched
Check again, maybe a typo or something.
There's another way to accomplish this as explained here https://bbs.archlinux.org/viewtopic.php … 28#p999328
Running GUI apps either GTK or QT or anything else as root has been and always will be risky, as you could damage your system beyond repair. When people talk about "huge security risk" they are usually referring to servers and login via ssh into them, then running a GUI as root which is of course a very bad idea. However, if you're the only one using your computer/OS, and you don't ssh into it, then it is probably safe to run GUI apps in a root environment, you just need to be careful when doing so and be aware that whatever happens after that is all on you.
