#1 2020-09-05 09:13
cpcnw
Bootable Q4OS SSD on USB 3.0
Is the above possible (even if not recommended!)
I tried to run the installer and could choose the destination drive and partition scheme but grub wrote to the 1st HDD in the box not the target installation drive.
#2 2020-09-05 09:34
Re: Bootable Q4OS SSD on USB 3.0
What Q4OS image ?
#3 2020-09-05 09:37
.. and what installation method ?
#4 2020-09-05 10:46
cpcnw
Q4OS Centaurus, Trinity, install-cd - 64bit / x64
Used the normal install routine where you can choose various options... I did reduce the size of swap as % of drive as it nearly split 50/50
But I don't remember being asked about target for grub?
#5 2020-09-05 10:53
Is it EFI or legacy BIOS system ?
#6 2020-09-05 10:57
cpcnw
Legacy
#7 2020-09-05 11:58
Yes, Q4OS installer installs Grub bootloader to the first device automatically, if Q4OS is the only operating system installed. A way would be to reinstall bootloader manually as installation finishes.
