#1 2020-01-25 23:22
cpcnw
Reliable DVD Rip to ISO
Hi,
Just tried K9Copy and it started OK but then just went on forever making disc thrashing noises.
Anyone got a good suggestion on how they make DVD backups on Q4OS?
Cheers!
#2 2020-01-25 23:26
cpcnw
Re: Reliable DVD Rip to ISO
Ignore that - looks like K3B is doing the job fine!
Also there was a large greasy thumb print on the disc - Doh!
#3 2020-01-26 03:46
K3b is my favorite but I also use Brasero or XFburn that work well.
#4 2020-01-26 10:12
cpcnw
Both failed. Now trying dvdbackup CLI tool. It started with a number of the following
*** Zero check failed in src / ifo_read.c:855
    for cell_position[i].zero_1 = 0x08
which makes me think the disc is damaged. There does seem to be a number of surface aberrations.
Just now dvdbackup is making a similar noise that K9Copy did - disc thrashing!
As an aside DVDFab on that other OS didn't seem to have any trouble, suspect it just fills bad cells?
Here we go...
Error reading VTS_02_3.VOB at block 1497086, read error returned
padding 512 blocks
#5 2020-01-26 11:02
cpcnw
Just tried with a different disc and worked perfectly. Odd thing is the disc I started with looks either good or very good in terms of surface scratches. On a quick look you'd even say it was very good to mint. Is there any scheme that used to be used [Disc is from 2007] that attempts to prevent copying / backup that somehow fools software into detecting bad sectors etc when on read back is fine?
#6 2020-01-27 00:22
Ive had so few issues with K3b honestly it tends to be issues with the disc. Using a flashlight many times you can spot very fine scratches or imperfections that can cause issues but temperature or accidentally contact with substances on the surface could cause issues.
