#1 2019-11-05 07:36
deanr
Chromium updates?
I use Chromium (Version 76.0.3809.100 (Developer Build) built on Debian 10.0, running on Debian 10.1 (64-bit)) and for a week now I've been getting messages prompting me to update and warning me of security issues.
When I click on the 'update now' button, however, it takes me to a Google Chrome update page which, even once installed, does nothing to prevent more update messages on Chromium. I tried uninstalling Chromium and reinstalling via the Q4OS Software Centre and this hasn't solved the problem.
Will there be an update via the repositories soon? Should I switch back to Chrome for security reasons?
Thanks.
#2 2019-11-05 08:52
Kevin
Re: Chromium updates?
Same problem here, can chromium be updated & add to repository ?
Thanks.
#3 2019-11-05 09:38
It's a general Debian based Chromium issue, the Debian team takes care about its security. We would guess, Chromium could take an update soon. In the meantime we will check a possibility to fix the issue somehow.
#4 2019-11-06 20:32
deanr
OK. Thanks for the response.
#5 2019-11-08 12:47
The issue is confirmed and reported as a Debian bug https://bugs.debian.org/cgi-bin/bugrepo … bug=943668
#6 2019-11-08 16:50
deanr
Thanks. So it's just a case of waiting for a fix to come down in an update through the repos, right?
#7 2019-11-08 17:32
Yes
#8 2019-11-10 21:05
The issue should be fixed now, you only need to update your system from repositories.
#9 2019-11-11 13:49
Kevin
Thanks !
#10 2019-11-13 18:50
deanr
Yup! All good ;-)
