#1 2019-10-18 16:28
Lioh
Firefox default handler for directories
Hi all,
when I click on the 'open containing folder' in the Firefox Downloads lists it opens with Dolphin instead of Konqueror. I have already tried to set:
xdg-mime default kfmclient_dir.desktop inode/directory
but without success. How can I achieve that the default handler for inode/directory is Konqueror instead of Dolphin?
Greetings
Lioh
#2 2019-10-18 19:33
Re: Firefox default handler for directories
We can confirm the issue. We have successfully tested the workaround from here https://askubuntu.com/questions/530779/ … 123#590123
We will investigate the issue and provide fix as soon as possible. Thanks for reporting.
#3 2019-10-22 10:17
The issue is now officially fixed, see the changelog https://www.q4os.org/changelog-q4os3, you only need to update your system.
