#1 2019-05-31 16:25
mrflavius
Apt -get update dont work
Hi. I was trying to install the tor browser through a tutorial and I do not know what I did wrong and now I can not update ...
terminal :
alumno@q4os-desktop:~$ sudo apt-get update
E: No se pudo encontrar el método /usr/lib/apt/methods/https.
N: ¿Está instalado el paquete apt-transport-https?
#2 2019-05-31 16:42
jotapesse
Re: Apt -get update dont work
Hi! Have you changed your sources lists in any way?
apt-get is complaining about not having "apt-transport-https" package installed because somewhere on your sources lists files it is setup a repository access with "https" secure transport. You may try to install the required package and see if resolves it.
$ sudo apt install apt-transport-https
#3 2019-05-31 16:48
mrflavius
alumno@q4os-desktop:~$ $ sudo apt install apt-transport-https
bash: $: no se encontró la orden
alumno@q4os-desktop:~$ $ sudo apt-get  install apt-transport-https
I follow this tutoral : https://securityhacklabs.net/forum/dist … n-debian-9
#4 2019-05-31 16:57
jotapesse
smile Just write on terminal (without the $):
#5 2019-05-31 17:01
mrflavius
alumno@q4os-desktop:~$ sudo apt install apt-transport-https
Leyendo lista de paquetes... Hecho
Creando árbol de dependencias
Leyendo la información de estado... Hecho
E: No se ha podido localizar el paquete apt-transport-https
sad
#6 2019-05-31 17:07
jotapesse
Can you update first? Write on terminal (without the $):
$ sudo apt update
Also please report what is the result of the command (always without the $):
$ qrepolist
#7 2019-05-31 17:19
jotapesse
Also, according to the tutorial you followed you edited the /etc/apt/sources.list with the lines:
deb https://deb.torproject.org/torproject.org stretch main
deb-src https://deb.torproject.org/torproject.org stretch main
You must comment out these lines (to disable them), edit and save so that results:
# deb https://deb.torproject.org/torproject.org stretch main
# deb-src https://deb.torproject.org/torproject.org stretch main
Then you should be able to update and install (always without the $):
$ sudo apt update
If you succeed then you can enable (remove the comment preceding "#") those lines on /etc/apt/sources.list, edit and save so that results:
#8 2019-05-31 17:43
@mrflavius
What version of Q4OS do you use ? Apt-transport-https is a hard dependency of q4os-desktop for Scorpion, so it couldn't be easily removed from system.
#9 2019-05-31 18:27
mrflavius
@mrflavius
What version of Q4OS do you use ? .
i dont know...
(I do not know how to know)
#10 2019-05-31 18:42
mrflavius
$ sudo apt update
solved (I think ...)
sudo apt-get update :
Ign http://packages.siduction.org jessie-backports InRelease
Obj http://www.deb-multimedia.org jessie InRelease
Obj http://q4os.org q4os-1-0-cn InRelease
Ign http://ftp.debian.org jessie InRelease
Ign http://packages.siduction.org jessie-backports Release.gpg
Obj http://ftp.debian.org jessie-updates InRelease
Obj http://security.debian.org jessie/updates InRelease
Obj http://q4os.org jessie InRelease
Ign http://ftp.debian.org jessie-backports InRelease
Obj http://ftp.debian.org jessie Release.gpg
Des:1 http://security.debian.org jessie/updates/contrib i386 Packages [2.526 B]
Ign http://ftp.debian.org jessie-backports Release.gpg
Des:2 http://security.debian.org jessie/updates/non-free i386 Packages [4.554 B]
Des:3 http://security.debian.org jessie/updates/main i386 Packages [685 kB]
Obj http://www.deb-multimedia.org jessie/main i386 Packages
Des:4 http://security.debian.org jessie/updates/contrib Translation-en [1.211 B]
Obj http://www.deb-multimedia.org jessie/non-free i386 Packages
Obj http://q4os.org q4os-1-0-cn/main i386 Packages
Des:5 http://security.debian.org jessie/updates/main Translation-en [345 kB]
Obj http://www.deb-multimedia.org jessie/main Translation-en
Des:6 http://security.debian.org jessie/updates/non-free Translation-en [11,8 kB]
Obj http://www.deb-multimedia.org jessie/non-free Translation-en
Obj http://q4os.org jessie/main i386 Packages
Obj http://ftp.debian.org jessie/main i386 Packages
Obj http://ftp.debian.org jessie/contrib i386 Packages
Obj http://ftp.debian.org jessie/non-free i386 Packages
Obj http://ftp.debian.org jessie/contrib Translation-en
Obj http://ftp.debian.org jessie/main Translation-es
Ign http://q4os.org q4os-1-0-cn/main Translation-es_AR
Obj http://ftp.debian.org jessie/main Translation-en
Obj http://ftp.debian.org jessie/non-free Translation-en
Ign http://q4os.org q4os-1-0-cn/main Translation-en
Ign http://q4os.org jessie/main Translation-es_AR
Ign http://q4os.org jessie/main Translation-en
Err http://packages.siduction.org jessie-backports/main i386 Packages
  404  Not Found
Err http://packages.siduction.org jessie-backports/contrib i386 Packages
  404  Not Found
Err http://packages.siduction.org jessie-backports/non-free i386 Packages
  404  Not Found
Ign http://packages.siduction.org jessie-backports/contrib Translation-es_AR
Ign http://packages.siduction.org jessie-backports/contrib Translation-en
Ign http://packages.siduction.org jessie-backports/main Translation-es_AR
Ign http://packages.siduction.org jessie-backports/main Translation-en
Ign http://packages.siduction.org jessie-backports/non-free Translation-es_AR
Ign http://packages.siduction.org jessie-backports/non-free Translation-en
Err http://ftp.debian.org jessie-backports/main Sources
  404  Not Found [IP: 130.89.148.12 80]
Err http://ftp.debian.org jessie-backports/contrib Sources
Err http://ftp.debian.org jessie-backports/non-free Sources
Err http://ftp.debian.org jessie-backports/main i386 Packages
Err http://ftp.debian.org jessie-backports/contrib i386 Packages
Err http://ftp.debian.org jessie-backports/non-free i386 Packages
Ign http://ftp.debian.org jessie-backports/contrib Translation-es_AR
Ign http://ftp.debian.org jessie-backports/contrib Translation-en
Ign http://ftp.debian.org jessie-backports/main Translation-es_AR
Ign http://ftp.debian.org jessie-backports/main Translation-en
Ign http://ftp.debian.org jessie-backports/non-free Translation-es_AR
Ign http://ftp.debian.org jessie-backports/non-free Translation-en
W: Fallo al obtener http://ftp.debian.org/debian/dists/jess … /InRelease  Noa esperada «main/binary-i386/Packages» en el archivo «Release» (entrada incorrecta mal formado)
W: Fallo al obtener http://packages.siduction.org/lxqt/dist … ts/main/ot Found
W: Fallo al obtener http://packages.siduction.org/lxqt/dist … orts/contr  Not Found
W: Fallo al obtener http://packages.siduction.org/lxqt/dist … rts/non-f4  Not Found
W: Fallo al obtener http://ftp.debian.org/debian/dists/jess … ain/source: 130.89.148.12 80]
W: Fallo al obtener http://ftp.debian.org/debian/dists/jess … ontrib/sou[IP: 130.89.148.12 80]
W: Fallo al obtener http://ftp.debian.org/debian/dists/jess … on-free/so [IP: 130.89.148.12 80]
W: Fallo al obtener http://ftp.debian.org/debian/dists/jess … n/binarynd [IP: 130.89.148.12 80]
W: Fallo al obtener http://ftp.debian.org/debian/dists/jess … b/binFound [IP: 130.89.148.12 80]
W: Fallo al obtener http://ftp.debian.org/debian/dists/jess … on-free/bi Found [IP: 130.89.148.12 80]
E: No se han podido descargar algunos archivos de índice, se han omitido, o se han u lugar.
alumno@q4os-desktop:~$ sudo apt-get dist-upgrade
Calculando la actualización... Listo
0 actualizados, 0 nuevos se instalarán, 0 para eliminar y 0 no actualizados.
#11 2019-05-31 19:07
You are using Q4OS 1 Orion old-stable based on Debian Jessie, as we can see from the log posted above. We can highly recommend you to use Q4OS 2 Scorpion, the current stable version, if possible.
#12 2019-05-31 21:50
mrflavius
1-Is there any way to update it or should I do a new installation? (from scratch)
2-so I put in my previous post the problem is solved, right?
#13 2019-06-01 10:05
1. You need to perform a new installation.
2. It is not solved completely. You need to remove "siduction" and "jessie-backports" repositories from your sources.list, as they are not supported anymore. Once removed do full system upgrade in terminal:
and post back a result.
#14 2019-06-01 17:12
mrflavius
I do not know how to remove the repositories ...
(I do not intend to use a tutorial on the web again and ruin everything again,)
roll
#15 2019-06-01 17:17
Just edit related files in /etc/sources.list.d/*.list and follow the advice by Jotapesse from here https://www.q4os.org/forum/viewtopic.ph … 382#p15382 and comment out repositories "siduction" and "jessie-backports"
#16 2019-06-01 19:56
mrflavius
1-I've erased everything related to Tor.
2-repositories "siduction" and "jessie-backports" : I have deleted everything related to these repositories but I still see an error after the update.
alumno@q4os-desktop:/etc/apt/sources.list.d$ ls
10_q4os.list                     jd-team-jdownloader-jessie.list~
10_q4os.list.save                jd-team-jdownloader-jessie.list.save
12_qtde.list                     jd-team-jdownloader-jessie.list.save~
12_qtde.list.save                mozilla-debian.list.save
20_debian_jessie.list            mscore-ubuntu-mscore-stable-jessie.list
20_debian_jessie.list.save       mscore-ubuntu-mscore-stable-jessie.list~
deb-multimedia-ipc.list          mscore-ubuntu-mscore-stable-jessie.list.save
google-chrome.list               q4p-deb-multimedia-20150815035157-uxN.list.save
google-chrome.list~              shkn-xnoise-jessie.list
google-chrome.list.save          shkn-xnoise-jessie.list~
jd-team-jdownloader-jessie.list  shkn-xnoise-jessie.list.save
alumno@q4os-desktop:/etc/apt/sources.list.d$ sudo apt-get update
Obj [url]http://www.deb-multimedia.org[/url] jessie InRelease
Obj [url]http://q4os.org[/url] q4os-1-0-cn InRelease
Ign [url]http://ftp.debian.org[/url] jessie InRelease
Obj [url]http://ftp.debian.org[/url] jessie-updates InRelease
Obj [url]http://security.debian.org[/url] jessie/updates InRelease
Obj [url]http://q4os.org[/url] jessie InRelease
Obj [url]http://ftp.debian.org[/url] jessie Release.gpg
Des:1 [url]http://security.debian.org[/url] jessie/updates/contrib i386 Packages [2.526 B]
Des:2 [url]http://security.debian.org[/url] jessie/updates/non-free i386 Packages [4.554 B]
Obj [url]http://www.deb-multimedia.org[/url] jessie/main i386 Packages
Des:3 [url]http://security.debian.org[/url] jessie/updates/main i386 Packages [686 kB]
Obj [url]http://www.deb-multimedia.org[/url] jessie/non-free i386 Packages
Obj [url]http://q4os.org[/url] q4os-1-0-cn/main i386 Packages
Des:4 [url]http://security.debian.org[/url] jessie/updates/contrib Translation-en [1.211 B]
Obj [url]http://www.deb-multimedia.org[/url] jessie/main Translation-en
Des:5 [url]http://security.debian.org[/url] jessie/updates/main Translation-en [345 kB]
Des:6 [url]http://security.debian.org[/url] jessie/updates/non-free Translation-en [11,8 kB]
Obj [url]http://www.deb-multimedia.org[/url] jessie/non-free Translation-en
Obj [url]http://ftp.debian.org[/url] jessie/main i386 Packages
Obj [url]http://ftp.debian.org[/url] jessie/contrib i386 Packages
Obj [url]http://ftp.debian.org[/url] jessie/non-free i386 Packages
Obj [url]http://ftp.debian.org[/url] jessie/contrib Translation-en
Obj [url]http://q4os.org[/url] jessie/main i386 Packages
Obj [url]http://ftp.debian.org[/url] jessie/main Translation-es
Obj [url]http://ftp.debian.org[/url] jessie/main Translation-en
Obj [url]http://ftp.debian.org[/url] jessie/non-free Translation-en
Ign [url]http://q4os.org[/url] q4os-1-0-cn/main Translation-es_AR
Ign [url]http://q4os.org[/url] q4os-1-0-cn/main Translation-en
Ign [url]http://q4os.org[/url] jessie/main Translation-es_AR
Ign [url]http://q4os.org[/url] jessie/main Translation-en
W: Fallo al obtener [url]http://ftp.debian.org/debian/dists/jessie-updates/InRelease[/url]  No se pudo encontrar la entrada esperada «main/binary-i386/Packages» en el archivo «Release» (entrada incorrecta en «sources.list» o fichero mal formado)
E: No se han podido descargar algunos archivos de índice, se han omitido, o se han utilizado unos antiguos en su lugar.
#17 2019-06-01 22:11
If you use the package inxi you could issue the command
inxi -r
which will give you something similar to this...
Repos:     Active apt sources in file: /etc/apt/sources.list.d/10_q4os.list
           deb http://q4os.org/q4repo q4os-2-0-cn main
           Active apt sources in file: /etc/apt/sources.list.d/12_qtde.list
           deb http://q4os.org/qtderepo stretch main
           Active apt sources in file: /etc/apt/sources.list.d/20_debian.list
           deb http://ftp.debian.org/debian/ stretch main contrib non-free
           deb http://security.debian.org/debian-security/ stretch/updates main contrib non-free
           deb http://ftp.debian.org/debian/ stretch-updates main contrib non-free
           Active apt sources in file: /etc/apt/sources.list.d/dvpck_q4os-chrome.list
           deb [arch=amd64] http://q4os.org/qextrepo stretch-chrome-cn main
           Active apt sources in file: /etc/apt/sources.list.d/dvpck_q4os-libreoffice.list
           deb http://q4os.org/qextrepo stretch-libreoffice-cn main
           Active apt sources in file: /etc/apt/sources.list.d/google-chrome.list
           deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
This tells you which repositories are active and the file that contains them, from there it will be easier to remove (or comment out) the offending entries.
