#1 2018-11-28 18:42
Jerome
dconf-editor doesn't save changes
I'm using the gnumeric spreadsheet application and would like to save the toolbar layout in a particular configuration. For some reason the settings aren't saved between program runs. After a bit of googling I discovered that the dconf-editor can be used to save the settings (apt-get install dconf-editor) but after selecting the changes I want it doesn't save them. However, if I run the dconf-editor as root (after sudoing at the command prompt) it does save the configuration, but then I have to run gnumeric as root too in order to see them.
Any suggestions? Thanks.
p.s. I'm using the latest version of scorpion.
#2 2018-11-28 19:31
Re: dconf-editor doesn't save changes
Please try to run gnumeric as well as dconf-editor the following way:
$ unset XDG_CONFIG_HOME && gnumeric
$ unset XDG_CONFIG_HOME && dconf-editor
save changes and check them. Report back the result.
#3 2018-11-28 20:19
Jerome
Hi Team,
When I use those commands and make the changes in the editor, gnumeric does open with the correct configuration, but only when I start it with unset XDG_CONFIG_HOME && gnumeric, not when I run it using the desktop icon.  But I can just change the command to run gnumeric in the icon properties tab (it works fine)...
Thanks!
#4 2018-11-28 20:40
Thanks, we can confirm a glitch in some GTK applications, as they don't handle the XDG home variable properly. We will try to fix that in the next Q4OS release.
#5 2018-11-29 09:51
The issue is now fixed, you only need to update your system, so run in terminal:
$ sudo apt-get update
$ sudo apt-get dist-upgrade
Reboot.
#6 2018-11-29 15:38
Jerome
Awesome! :-)
