#1 2018-09-19 14:56
jschall
How to add a keyboard shortcut to an executable file?
I want to launch the executable file /usr/bin/apwal (http://apwal.free.fr/index.html), which I installed with Synaptic, via a keyboard shortcut, preferably <ALT>+<SPACE>.
The Keyboard Shortcuts utility only assigns shortcuts to programs that are already in the Menu.
My apwal launcher can be launched from the RUN command and I have also added it to my Quick Launcher in the Panel.
But it is nowhere to be found in the Menu.
So, is there a way to add the executable /usr/bin/apwal to the Menu, so I could then add a keyboard shortcut?
Alternatively, can I simply edit a text file to add the keyboard shortcut?
#2 2018-09-19 15:07
Re: How to add a keyboard shortcut to an executable file?
jschall wrote:
... is there a way to add the executable /usr/bin/apwal to the Menu ...
Yes, you need to create 'apwal.desktop' file in the '/usr/share/applications/' directory. It could look for example like the following:
[Desktop Entry]
Name=_subst_an_application_name
GenericName=something
Comment=something
Exec=/usr/bin/apwal
Icon=subst_the_icon_name
Type=Application
Terminal=false
Categories=System;
OnlyShowIn=TDE;
#3 2018-09-19 15:40
You could create a .desktop file which would launch apwal and then use that attach a keyboard shortcut.
[Desktop Entry]
Name=Apwal Launcher
Exec=/usr/bin/apwal
Type=Application
Comment=application Launcher
Categories=Qt;TDE;Utility;X-TDE-Utilities-Desktop;
NoDisplay=false
I used this as the content of my file and place it as /usr/share/applications/apwal.desktop then went to Keyboard Shortcuts and added Ctrl+space as shortcut and it works fine here.
I went away from the pc for a while (damn visitors! smile ) and went to post this and saw the devs beat me, but will post it anyway as mine is minutely different as I use the desktop utilities section.
#4 2018-09-19 16:59
jschall
Thank you, Q4OS Team and Dai_Trying.
I saved /usr/share/applications/apwal.desktop.
But where is it in the Menu?
#5 2018-09-19 17:09
You can run kate using 'sudo' command:
$ sudo kate
or run filemanager in root mode from start menu, navigate the file and open it to edit.
#6 2018-09-19 17:09
jschall
Thank you, Q4OS Team.
I found it it in the Menu under Programs/Accessories/Utilities/Desktop.
But <Alt>+<Space> doesn't work - why not?
<Alt>+<A> works, though.
#7 2018-09-19 21:32
when I tested it worked with Ctrl+space but I didn't test it with Alt+space and am out at moment so cannot check until I get back. Did you set the key combo in the keyboard shortcuts?
#8 2018-09-19 21:40
'Alt+Space' is predefined for switching between different keyboard layouts. You would need to revoke this shortcut first
#9 2018-09-19 23:12
jschall
Thanks! Now I can use Alt+Space to launch my launcher.
