#1 2018-08-16 20:40
BrJPedro
Can I change the Lateral image text in start menu?
Hi
Is there a way to change the lateral image in 'Trinity Classic' start menu?
João Pedro -o- @12h01
#2 2018-08-16 20:50
Re: Can I change the Lateral image text in start menu?
You can define an image in config file '$HOME/.trinity/share/config/kickerrc', group 'KMenu', key 'SideTileName'. If you enter a file without absolute path, the system will take it from the '/opt/trinity/share/apps/kicker/pics/' directory.
EDIT: fixed wrong path
#3 2018-08-16 21:38
You can define an image in config file '$HOME/.trinity/config/kickerrc', group 'KMenu', key 'SideTileName'. If you enter a file without absolute path, the system will take it from the '/opt/trinity/share/apps/kicker/pics/' directory.
Correct path for file to edit should be '$HOME/.trinity/share/config/kickerrc', (on my system it is anyway smile )
#4 2018-08-16 21:43
@Dai_trying
Yes of course, thanks for the correction smile
