#1 2018-08-12 09:06
Beginnerq4os
audio/videoplayer autracity/minitube compatible to Q4os ?
Hi community,
the audioplayer autracity and the small-seized videoplayer minitube
were written for ubuntu.
Are they compatible to Q4os as well ? Or can anyone recommend another player with low hardware requirements?
Many thanks for replys in advance!
#2 2018-08-12 09:23
Re: audio/videoplayer autracity/minitube compatible to Q4os ?
Minitube is available from Synaptic package manager or you can install with the following command
sudo apt install minitube
I cannot find any reference to a package called Autracity but if you actually mean Audacity then that too is available via Synaptic package manager or the following command in a terminal
sudo apt install audacity
#3 2018-08-13 06:59
I found smplayer worked well.
