#1 2016-01-18 08:14
bobby
XPQ4 i386 is for 64bit Intel too - XPQ4 x64 for AMD Only
The i386 XPQ4 works on my Intel Duo 2.2ghz 64bit but, the XPQ4 x64 version does not.
So I will need to build 3 different Custom Q4OS builds to cover all pc processors:
1 - Intel i366 Build = Q4OS i386 + XPQ4 i386
1-  Intel 64 bit Build = Q4OS x64 + XPQ4 i386
1 - AMD 64 bit Build = Q4OS x64 + XPQ4 x64
Does this sound correct ?
Also, will any configuration possibly work on a Intel power MAC ?
Thanks ahead for help.
Bobby
No Longer Using Q4OS
#2 2016-01-18 10:18
Re: XPQ4 i386 is for 64bit Intel too - XPQ4 x64 for AMD Only
Intel 64bit and AMD 64bit should be the same for Debian binaries. You may have i386 Debian/Q4OS installed on your 'Intel Core Duo' machine. Check it with:
$ dpkg --print-architecture
You will have to contact third-party devs for support on non Q4OS software.
#3 2016-01-18 11:24
bobby
Q4OS Team,
result:  amd64
$ hostnamectl
result:
   Static hostname: q4osdev
         Icon name: computer-laptop
           Chassis: laptop
        Machine ID: 9994fc73fe1d441783d2d3fadc85eb47
           Boot ID: d8d59a27a9044605b4fdeaa88a76e380
  Operating System: Debian GNU/Linux 8 (jessie)
            Kernel: Linux 3.16.0-4-amd64
      Architecture: x86-64
The XPQ4 x64 package will not install but, the XPQ4 i386 installs and works okay.
This laptop is an emachine E725 (before Acer bought them)
I put in a different hard drive and build from 100% new and See what happens.
Thanks for help on this.
Bobby
#4 2016-01-20 07:26
bobby
Please show this as resolve
Installed Q4OS x64 and then added XPQ4 before any desktop configuration changes and the "Wrong Architecture:" error went away.
Operator error ? Seems like it smile
Bobby
