#1 2016-01-13 01:42
granul
Visual effect [SOLVED]
Hi!
I have 2 questions
1. how do disable disable visual effect on q4os
2. how do make icons bigger on desktop
Thank great distro
#2 2016-01-13 09:20
Re: Visual effect [SOLVED]
1. Control panel -> Desktop -> Window Behaviour -> Translucency -> uncheck 'Enable the Trinity window composition manager'
  or click 'Turn on Desktop effects' on Welcome screen and click 'Revert to defaults' button.
2. Enable setting of icons themes, see chapter '4.3. Is it possible to change icon theme ?' http://www.q4os.org/dqa011.html#desktop.3
Go to Icons properties in Control panel and set size of desktop icons.
#3 2016-01-14 13:53
granul
Thank you
