#1 2016-01-11 01:28
bobby
LIve HD works what about whole CD in RAM ?
I was able to install Q4OS LiveCD to my hard drive as a LiveCD Image and it boots.
Is it an easy mod to push the whole LiveCD in to memory and run it LIVE in RAM ?
Might need more Memory as I only have 3GB in my fastest computer.
THanks,
Bobby
No Longer Using Q4OS
#2 2016-01-11 08:13
Re: LIve HD works what about whole CD in RAM ?
Yes, you need at least 1GB of RAM, run in terminal:
$ sudo live-toram
#3 2016-01-11 10:24
bobby
Tried it but, it failed
Duo Core 2.2 Ghz  intel / 64bit / 3GB memory
Q4OS v 1.4.5  x64
Results:
adminq@debian:~$ sudo live-toram
P: Copying filesystems to memory.
I: This may take a while...
‘/lib/live/mount/medium/live/filesystem.squashfs’ -> ‘/tmp/live’
expr: syntax error
expr: syntax error
Oh, I won't be able to sleep until I can experience LIVE RAM smile
Should I try sudo live-toram on my 32 bit intel computer with 1.5GB memory ?
Thanks,
Bobby
#4 2016-01-11 10:46
It probably already resides in ram, done automatically on boot. Try to unmount live cd, eject it and ride the system.
#5 2016-01-11 16:46
bobby
Q4OS Team,
Okay.  Now going to seek out RAM Riding smile
#6 2016-01-11 18:59
bobby
WOW !  Maybe its just me but, its seems to be faster with the both my hard drive removed and LiveCD removed from the CD-ROM Drive.
Q4OS Team, you were correct, filesystem loads to RAM DRIVE automatically; all 1.6GB
Odd thing though:
If I leave the LiveCD in the drive I can run sudo live-toram ----- And will start to copy to ram.
Could a flag be set where sudo live-toram will not run after filesystem is loaded to RAM DRIVE ?
If I run sudo live-toram it corrupts things:  Network Places stops working.
#7 2016-01-11 19:07
bobby
All Kinds of options to run Q4OS,
What about Net Boot and this could draw a large group of users who have older computers.  As well as boot PXE compatible NICs installed.
Most new better quality routers now have a usb connection for a Net Storage Drive.
Has Q4OS Team considered (or is it easily possible?)  to load Q4OS (would have to be both 686 & x64) to a network share and run computers as Q4OS clients ?
Where the filesystem remains on the NAS and clients only have the boot files on them ?   A lot of other Linxu flavors do this.
Much older computers could be used in this manner with 512 MB and a swapfiile on a hard drive or thumb drive.
I would love to support this kind of arrangement.
