#26 2017-11-24 18:23
lucbertz
Re: Systemback`s alternative.
Thank you for your reply.
To be more clear, I'm not asking to developers to include Linux Live Kit in Q4OS. I guess, how much Q4OS is compatible with Debian Stretch?
Linux Live Kit developer says it can be used with any Linux distribution (probably optimistic) and he realized Slax using Debian Stretch as source system.
I'm worried to loose time trying to make a custom Q4OS live CD with Linux Live Kit scripts due to incompatibilities with Stretch. I ask here if someone already tried to do it or if there are components or customizations in Q4OS which could make it too hard.
less is more
#27 2017-11-24 23:17
I haven't tried it as i have no need for it, but I'm sure this will prompt some others to at least try it out smile
#28 2017-11-24 23:21
Based on the devs comments Q4OS is very compatible with Debian Stretch but I havent tried it either so cant give any feedback.
#29 2018-01-19 16:40
lucbertz
Finally, using Linux Live Kit (https://www.linux-live.org/) and a 4.4 kernel with aufs support (taken from Ubuntu Server) I obtained a portable Q4OS.
My solution needs refinements, like to find aufs.ko module in a kernel provided by Q4OS (do you have any hint?), but it seems to work.
less is more
#30 2018-05-06 19:56
Linux Mint has Timeshift preinstalled, and it`s really works there. So, it should work on Q4OS too.
#31 2018-05-06 22:24
Timeshift looks pretty good from the howto I just read, and backups are definitely an area that should be incorporated into any OS. Maybe the devs could create a Q4OS installer for it to make it easier for newer users to try. smile
#32 2018-05-10 07:49
Yes, Timeshift looks fine. The most easy, and likely the clean, way we would recommend, is to download Timeshift 'deb' package from their github project https://github.com/teejee2008/timeshift/releases , and install in Q4OS:
$ sudo apt install <path_to_package>/timeshift-v18.4-amd64.deb
#33 2019-01-14 17:09
lucbertz
In order to build a ISO of the currently installed system, does anyone tried RefractaSnapshot?
It is available here:
https://sourceforge.net/projects/refracta/files/tools/
I'm trying it with Debian Buster and it seems to work. I will try it with Centaurus, when a 32 bit beta will be available.
less is more
#34 2019-08-18 18:26
Tested Timeshift - works very well on Q4OS Scorpion!
#35 2019-08-18 21:28
Timeshift is pretty much standard in the Ubuntu based distros, like Mint,Zorin,etc.
#36 2020-11-15 03:20
bobby
Systemback is being developed again and current version 1.9.4 was posted to Sourceforge by Developer in May 2020. And it works on Q4OS !
https://sourceforge.net/projects/system … 9-4/files/
No Longer Using Q4OS
#37 2020-11-15 18:30
Thanks for the heads up, Ill check this out.
