#1 2020-06-14 18:29
8Gerrard
Package system busy
hello i installed q4os trinity i really like the os cause of the xp feel but it does not allow me to install packages and from another thread they wanted to see the check-apt-busy and ps -ef output so here it is:ozcanbc@ozcan-pc:~$ check-apt-busy
Process 980 has a write lock already!
Unable to lock: /var/lib/apt/lists/lock
Unable to lock: /var/lib/dpkg/lock
Unable to lock: /var/cache/apt/archives/lock
[CHKPKSYS] >> Package system status: Busy !
ozcanbc@ozcan-pc:~$ ps -ef
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 20:07 ?        00:00:01 /sbin/init
root         2     0  0 20:07 ?        00:00:00 [kthreadd]
root         3     2  0 20:07 ?        00:00:00 [rcu_gp]
root         4     2  0 20:07 ?        00:00:00 [rcu_par_gp]
root         6     2  0 20:07 ?        00:00:00 [kworker/0:0H-kblockd]
root         7     2  0 20:07 ?        00:00:03 [kworker/u8:0-i915]
root         8     2  0 20:07 ?        00:00:00 [mm_percpu_wq]
root         9     2  0 20:07 ?        00:00:01 [ksoftirqd/0]
root        10     2  0 20:07 ?        00:00:00 [rcu_sched]
root        11     2  0 20:07 ?        00:00:00 [rcu_bh]
root        12     2  0 20:07 ?        00:00:00 [migration/0]
root        14     2  0 20:07 ?        00:00:00 [cpuhp/0]
root        15     2  0 20:07 ?        00:00:00 [cpuhp/1]
root        16     2  0 20:07 ?        00:00:00 [migration/1]
root        17     2  0 20:07 ?        00:00:00 [ksoftirqd/1]
root        19     2  0 20:07 ?        00:00:00 [kworker/1:0H-kblockd]
root        20     2  0 20:07 ?        00:00:00 [cpuhp/2]
root        21     2  0 20:07 ?        00:00:00 [migration/2]
root        22     2  0 20:07 ?        00:00:01 [ksoftirqd/2]
root        24     2  0 20:07 ?        00:00:00 [kworker/2:0H-kblockd]
root        25     2  0 20:07 ?        00:00:00 [cpuhp/3]
root        26     2  0 20:07 ?        00:00:00 [migration/3]
root        27     2  0 20:07 ?        00:00:02 [ksoftirqd/3]
root        29     2  0 20:07 ?        00:00:00 [kworker/3:0H-kblockd]
root        30     2  0 20:07 ?        00:00:00 [kdevtmpfs]
root        31     2  0 20:07 ?        00:00:00 [netns]
root        32     2  0 20:07 ?        00:00:00 [kauditd]
root        33     2  0 20:07 ?        00:00:00 [khungtaskd]
root        34     2  0 20:07 ?        00:00:00 [oom_reaper]
root        35     2  0 20:07 ?        00:00:00 [writeback]
root        36     2  0 20:07 ?        00:00:00 [kcompactd0]
root        37     2  0 20:07 ?        00:00:00 [ksmd]
root        38     2  0 20:07 ?        00:00:00 [khugepaged]
root        39     2  0 20:07 ?        00:00:00 [crypto]
root        40     2  0 20:07 ?        00:00:00 [kintegrityd]
root        41     2  0 20:07 ?        00:00:00 [kblockd]
root        42     2  0 20:07 ?        00:00:00 [edac-poller]
root        43     2  0 20:07 ?        00:00:00 [devfreq_wq]
root        44     2  0 20:07 ?        00:00:00 [watchdogd]
root        46     2  0 20:07 ?        00:00:00 [kworker/2:1-events]
root        48     2  0 20:07 ?        00:00:08 [kswapd0]
root        66     2  0 20:07 ?        00:00:00 [kthrotld]
root        67     2  0 20:07 ?        00:00:00 [ipv6_addrconf]
root        78     2  0 20:07 ?        00:00:00 [kstrp]
root       115     2  0 20:07 ?        00:00:00 [acpi_thermal_pm]
root       147     2  0 20:07 ?        00:00:00 [ata_sff]
root       155     2  0 20:07 ?        00:00:00 [kworker/3:3-events_power_effici
root       160     2  0 20:07 ?        00:00:00 [kworker/2:2-events]
root       180     2  0 20:07 ?        00:00:00 [scsi_eh_0]
root       181     2  0 20:07 ?        00:00:00 [scsi_tmf_0]
root       182     2  0 20:07 ?        00:00:00 [scsi_eh_1]
root       183     2  0 20:07 ?        00:00:00 [scsi_tmf_1]
root       184     2  0 20:07 ?        00:00:00 [kworker/u8:3-events_unbound]
root       193     2  0 20:07 ?        00:00:00 [irq/109-ELAN120]
root       194     2  0 20:07 ?        00:00:00 [kworker/3:1H-kblockd]
root       195     2  0 20:07 ?        00:00:00 [kworker/2:1H-kblockd]
root       198     2  0 20:07 ?        00:00:01 [kworker/0:2-rtl8723be_pci]
root       227     2  0 20:07 ?        00:00:00 [kworker/0:1H-kblockd]
root       230     2  0 20:07 ?        00:00:00 [kworker/u9:0-hci0]
root       231     2  0 20:07 ?        00:00:00 [jbd2/sda1-8]
root       232     2  0 20:07 ?        00:00:00 [ext4-rsv-conver]
root       237     2  0 20:07 ?        00:00:00 [kworker/1:1H-kblockd]
root       274     2  0 20:07 ?        00:00:00 [ext4lazyinit]
root       286     1  0 20:07 ?        00:00:00 /lib/systemd/systemd-udevd
root       333     2  0 20:07 ?        00:00:00 [asus_wireless_w]
root       356     2  0 20:07 ?        00:00:00 [kmemstick]
root       372     2  0 20:07 ?        00:00:00 [led_workqueue]
root       375     2  0 20:07 ?        00:00:00 [irq/129-mei_me]
root       421     2  0 20:07 ?        00:00:00 [i915/signal:0]
root       422     2  0 20:07 ?        00:00:00 [i915/signal:1]
root       423     2  0 20:07 ?        00:00:00 [i915/signal:2]
root       424     2  0 20:07 ?        00:00:00 [i915/signal:6]
root       428     2  0 20:07 ?        00:00:00 [cfg80211]
root       429     2  0 20:07 ?        00:00:00 [nvkm-disp]
root       430     2  0 20:07 ?        00:00:00 [kworker/u9:1-hci0]
root       432     2 11 20:07 ?        00:02:26 [kworker/1:3-events]
root       448     1  0 20:07 ?        00:00:02 /usr/sbin/haveged --Foreground -
root       464     2  0 20:08 ?        00:00:00 [ttm_swap]
systemd+   466     1  0 20:08 ?        00:00:00 /lib/systemd/systemd-timesyncd
message+   737     1  0 20:08 ?        00:00:00 /usr/bin/dbus-daemon --system --
root       738     1  0 20:08 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /r
root       739     1  0 20:08 ?        00:00:00 /usr/sbin/alsactl -E HOME=/run/a
root       741     1  0 20:08 ?        00:00:00 /usr/sbin/cron -f
root       742     1 33 20:08 ?        00:07:11 /usr/sbin/rsyslogd -n -iNONE
root       743     1  0 20:08 ?        00:00:01 /usr/sbin/NetworkManager --no-da
root       744     1  0 20:08 ?        00:00:00 /lib/systemd/systemd-logind
root       745     1  0 20:08 ?        00:00:00 /usr/lib/udisks2/udisksd
root       754     1  0 20:08 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
root       762     1  0 20:08 ?        00:00:00 /usr/bin/python3 /usr/share/unat
root       768     1  0 20:08 tty1     00:00:00 /sbin/agetty -o -p -- \u --nocle
root       773     1  0 20:08 ?        00:00:00 /opt/trinity/bin/tdm
root       784   773  1 20:08 tty7     00:00:16 /usr/lib/xorg/Xorg -br -defergly
root       806   743  0 20:08 ?        00:00:00 /sbin/dhclient -d -q -sf /usr/li
root       839   773  0 20:08 ?        00:00:00 -:0
root       841     1  0 20:08 ?        00:00:00 /opt/trinity/bin/tdekbdledsync
ozcanbc    877     1  0 20:08 ?        00:00:00 /lib/systemd/systemd --user
ozcanbc    878   877  0 20:08 ?        00:00:00 (sd-pam)
ozcanbc    889   839  0 20:08 ?        00:00:00 /bin/sh /usr/bin/x-session-manag
ozcanbc    905   877  0 20:08 ?        00:00:00 /usr/bin/dbus-daemon --session -
root       980     1  0 20:08 ?        00:00:00 /usr/share/apps/q4os_system/bin/
root      2256     2  0 20:14 ?        00:00:00 [kworker/2:0-events]
root      2382     2  0 20:16 ?        00:00:01 [kworker/u8:2-events_unbound]
ozcanbc   2490   889  0 20:17 ?        00:00:00 /usr/bin/ssh-agent x-session-man
root      2776     1  0 20:17 ?        00:00:00 /opt/trinity/bin/tde_dbus_hardwa
ozcanbc   3020   877  0 20:17 ?        00:00:00 /usr/bin/pulseaudio --daemonize=
root      3086     1  0 20:17 ?        00:00:00 start_tdeinit --new-startup +kcm
ozcanbc   3087     1  0 20:17 ?        00:00:00 [tdeinit] tdeinit Running...
ozcanbc   3090     1  0 20:17 ?        00:00:00 dcopserver [tdeinit] --nosid
ozcanbc   3093  3087  0 20:17 ?        00:00:00 tdelauncher [tdeinit] --new-star
ozcanbc   3095     1  0 20:17 ?        00:00:00 kded [tdeinit] --new-startup
ozcanbc   3106   889  0 20:17 ?        00:00:00 /opt/trinity/bin/tdeinit_phase1
ozcanbc   3109  3106  0 20:17 ?        00:00:00 sh -c kwrapper ksmserver
ozcanbc   3110  3109  0 20:17 ?        00:00:00 kwrapper ksmserver
ozcanbc   3112     1  0 20:17 ?        00:00:00 ksmserver [tdeinit]
root      3114     2  0 20:17 ?        00:00:00 [kworker/3:0-cgroup_destroy]
ozcanbc   3115  3087  0 20:17 ?        00:00:00 twin [tdeinit]
ozcanbc   3118  3115  0 20:17 ?        00:00:01 compton-tde
ozcanbc   3121     1  1 20:17 ?        00:00:09 /opt/trinity/bin/kdesktop
ozcanbc   3125  3121  0 20:17 ?        00:00:00 /opt/trinity/bin/kdesktop_lock -
ozcanbc   3134     1  0 20:17 ?        00:00:00 tdeio_uiserver [tdeinit]
ozcanbc   3139     1  0 20:17 ?        00:00:03 kicker [tdeinit]
ozcanbc   3146  3087  0 20:17 ?        00:00:00 tdeio_file [tdeinit] file /tmp/t
ozcanbc   3153     1  0 20:17 ?        00:00:00 kxkb [tdeinit]
ozcanbc   3157  3087  0 20:17 ?        00:00:00 /opt/trinity/bin/artsd -F 10 -S
ozcanbc   3159     1  0 20:17 ?        00:00:00 kaccess [tdeinit]
ozcanbc   3173     1  0 20:17 ?        00:00:00 knotify [tdeinit]
ozcanbc   3242     1  0 20:17 ?        00:00:00 klipper [tdeinit]
ozcanbc   3300     1  0 20:17 ?        00:00:01 tdenetworkmanager [tdeinit]
ozcanbc   3304     1  0 20:17 ?        00:00:02 tdepowersave [tdeinit]
ozcanbc   3340     1  0 20:17 ?        00:00:00 kmix -caption KMix -icon kmix -m
ozcanbc   3537  3087  0 20:20 ?        00:00:00 tdeio_file [tdeinit] file /tmp/t
ozcanbc   3797  3087  0 20:22 ?        00:00:00 /bin/sh -c ( dash /home/ozcanbc/
ozcanbc   3800  3797  1 20:22 ?        00:00:04 konqueror --profile webbrowsing
ozcanbc   3909  3087  0 20:22 ?        00:00:00 tdeio_http [tdeinit] https /tmp/
ozcanbc   3914  3087  0 20:22 ?        00:00:00 tdeio_http [tdeinit] https /tmp/
ozcanbc   3915  3087  0 20:22 ?        00:00:00 tdeio_http [tdeinit] https /tmp/
root      3969     2  0 20:23 ?        00:00:00 [kworker/1:1-events]
ozcanbc   4016  3087  0 20:23 ?        00:00:00 konqueror [tdeinit] --caption Me
root      4045     2  0 20:23 ?        00:00:00 [kworker/0:1-events]
ozcanbc   4118  3087  0 20:24 ?        00:00:00 tdeio_http [tdeinit] http /tmp/t
root      4121     2 32 20:24 ?        00:01:41 [kworker/1:2+events]
root      4330     1 96 20:28 ?        00:01:15 /lib/systemd/systemd-journald
root      4331     2  0 20:28 ?        00:00:00 [kworker/2:3]
root      4351     2  0 20:28 ?        00:00:00 [kworker/3:1-cgroup_destroy]
ozcanbc   4352  3087  0 20:28 ?        00:00:00 konsole [tdeinit]
ozcanbc   4356  4352  0 20:28 pts/1    00:00:00 bash
ozcanbc   4394  4356  0 20:29 pts/1    00:00:00 ps -ef
ozcanbc@ozcan-pc:~$
#2 2020-06-14 18:35
8Gerrard
Re: Package system busy
also i needed to do a simple install cause of this
#3 2020-06-14 20:02
The output of the "ps" command is not complete, so we cannot see the apt blocking process.
Please run the command in terminal:
$ ps -ef > /tmp/ps.log
and attach the "/tmp/ps.log" file generated here.
#4 2020-06-15 16:13
8Gerrard
thank you for your message but i fixed it by doing a reboot idk why but it fixed it i will continue using this os
