#1 2025-09-03 00:30
nathanjhill
Sound Works But Sound Icon Greyed Out
Good afternoon,
Here's a weird one.
I am using Q4 Beta, and everything works. Even sound. But the sound icon on the taskbar is greyed out. Volume works normally. Clicking to configure the sound shows a fully functioning set of speakers and microphone. The system is not muted.
Thoughts?
#2 2025-09-03 01:52
Re: Sound Works But Sound Icon Greyed Out
Thats really odd.
#3 2025-09-03 03:44
nathanjhill
Just an update: The sound icon is now NOT greyed out, but after a reboot, two sound icons showed up. I removed them both and added back just one. So strange. Maybe it has resolved?
#4 2025-09-03 04:02
Trying rebooting again and see if the single sound icon remains.
#5 2025-09-03 10:06
Are you using the default Breeze theme or did you set some another ? Which one ?
#6 2025-09-03 15:32
nathanjhill
I am using Debonaire at the moment. I did tinker with different themes so maybe that has something to do with it. It appears to be fixed now. So strange.
#7 2025-09-03 15:36
Debonaire will undergo some further refinements before Q4OS-6 stable is released.
