#1 2016-02-09 06:06
ThisGuy1996
Classic Shell Start menu Application for Q4OS?
This may seem far-fetched, but is it possible to have Classic shell on Q4OS?
#2 2016-02-09 19:33
jimdunn
Re: Classic Shell Start menu Application for Q4OS?
Or even better, how about PortableApps.Com's menu on Q4OS...  : )
(yes, jk)
#3 2016-02-09 21:17
ThisGuy1996
LOL, you're just too funny.
#4 2016-02-11 15:37
ThisGuy1996
Hey, that worked! Thanks for the idea!
#5 2016-02-11 17:03
bobby
Hey, what worked ?   No secrets here big_smile
No Longer Using Q4OS
#6 2016-02-11 17:41
ThisGuy1996
I installed Smithtech portable apps on my laptop. Take a look at the result.
#7 2016-02-11 17:42
ThisGuy1996
I installed Smithtech portable apps on my laptop and modified it a bit(Just changed the background). Take a look at the result.
jpeg THisScreenshot - 02022016 - 04:13:28 PM.jpeg, Size: 39.13 KiB, Downloads: 845
#8 2016-02-11 18:00
bobby
Well how about that ! Will check it out too.
#9 2016-02-11 18:07
ThisGuy1996
Okay. Just so you know that the shutdown buttons don't work. I just closes out the app. I hope to find a command to shutdown and add that as a shortcut to the menu.
#10 2016-02-16 02:37
Seeker
You don't need to
You already have Whiskermenu for XFCE desktop environment.
Even Q4OS has it's own start Menu from TDE Desktop Environment.
Each DE has it's own start Menu differently so you can't expect Classic Shell to develop on Linux DE.
If you wan to badly only you can get GNoMenu from Zorin.
However jimdunn's idea was interesting.
#11 2016-02-25 06:59
Seeker
I was talking about linux have XFCE which windows 7-8.1 users wanted.
OTOH Q4OS has it's own start menu which XP users wanted.
I do not talk anytrhing about mixing DE since the beginning.
#12 2016-03-11 00:57
ThisGuy1996
Sorry for the late reply, but how do I install GnoMenu? I've been having trouble with this for a while.
