#1 2019-02-09 19:01
debiandonder
snapd
Is it save to install snapd on Debian 9? I installed Firefox two weeks ago when I was still on Ubuntu 14.04  and the snap version of Firefox completely froze my system. mouse,keyboard or reset button didn't work.
I want to try to install clementine snap version because the one on Q40S doesn't work. It cannot identify or save music cd's to my pc.
#2 2019-02-10 02:05
Jaerrib
Re: snapd
Snapd works fine on Debian 9 (as well as Q4OS) in my experience.
#3 2019-02-10 03:20
debiandonder
Re: snapd
Thank you for your feedback. I tried Clementine snap version and ripped the music cd, but it didn't put it in the library like Rhythmbox did, that I used in the past. I now understand why people use Ubuntu based distribution. Everything is preconfigured to just work.
#4 2020-11-30 10:20
oboltyo
Re: snapd
Snap does NOT work fine in Q4OS - just installed it the other day to try it out. Must say, overall, I am impressed, however 1 out of 5 snaps I installed works, not even the snap store seems to come up.
#5 2020-11-30 10:38
Re: snapd
I would suggest you to install Timeshift from Q4OS Software Centre and make system backup using it before installing snaps. You will be able to revert all changes if something goes wrong.
You can read, how to use Timeshift here: https://github.com/teejee2008/timeshift and here https://github.com/teejee2008/timeshift/wiki
Latest Timeshift release is here: https://github.com/teejee2008/Timeshift/releases
#6 2020-11-30 12:52
Re: snapd
Hmmm...I don't use Ubuntu, don't quite like it. It's also preconfigured to fail, given the chance. Snaps are a waste of time, IMO. I prefer appimages; one file = one app and don't need to install/uninstall anything.
Timeshift's available from the repos:
$ apt-cache policy timeshift
timeshift:
  Installed: (none)
  Candidate:  19.01+ds-2+deb10u1
  version table:
     19.01+ds-2+deb10u1 500
        500 http://ftp.debian.org/debian buster/main amd64 Packages
So all you need to do is
sudo apt-get install timeshift
If you prefer a GUI approach, it is available on Q4OS software centre too. smile
#7 2020-12-06 00:14
Re: snapd
I don't care for snaps, but I despise appimages.  1/2 of them I've ever tried simply don't work, and those that do don't integrate into menus, and it just seems so "Windowsy" way of doing things.  Download this self-contained executable from this random spot that may or may not be actually malware and run it putting complete trust that it's what it says it is.  No thanks.
That said, snap has a lot of technical limitations that can prevent it from running, and probably won't be able to be worked around in an older distro like Debian 9.
#8 2020-12-06 14:13
Re: snapd
If people download whatever appimage they find, then it's no wonder they don't work. I only use appimages with a GitHub page. Yes, some may not work but most do. I'm currently using 21 appimages, they all work fine and some do integrate with the system; LibreOffice, Gimp, Gsubs, Inkscape, Joplin, Emacs, Code-OSS...some others, I just added them via KDE's edit applications menu. And I don't find them "windowsy" because unlike the "windowsy" apps, they do have support when using the official builds. If people behave in a "windowsy" way; download whatever app they found on the web without even know where they come from, "windowsy" situations can happen.
#9 2020-12-06 16:52
Re: snapd
In repos, there is Timeshift v19.01, which has a very important bug. This bug can lead to incorrectly restored snapshots. There is a workaround in v19.01, but new users may not know about it.
So I strongly suggest to use latest version from GitHub (currently v20.11.1). This bug has been (finally) fixed in this version.
