#1 2019-01-28 20:16
edilaq
Shutdown takes 30 minutes for the SQL Server service
Hi all:
In my team I was able to install SQL Server for Linux and it works well, the problem I have is that if the computer is suspended or hibernated, so I have not used the software (although the service is running), after a while of use turn off is stuck in the command line indicating that the SQL Server service will take 30 minutes to close, I would like to know how I could do so that this does not happen.
Greetings from Peru
