#1 2018-09-15 11:46
danielson
Anyone manage to install Joplin? [Solved]
Slowly trying to get away from Evernote and Onenote but the Linux alternatives are few.
Joplin seems to be the closest but can't get it installed.
Maybe someone has a better, easier alternative?
HP EliteBook 8460p - KDE - Intel i5-2520M CPU@2.5Ghz - 8 Gb RAM.
#2 2018-09-16 10:05
Re: Anyone manage to install Joplin? [Solved]
Did you try using the appimage available from the github page? It works on my system.
#3 2018-09-16 11:51
danielson
Yes.
But me no, no.
Did download it and double clicking on it opens up Brasero.
#4 2018-09-16 12:04
You should give it execute permissions
chmod +x Joplin-1.0.105-x86_64.AppImage
from the directory containing the file and then you should be able to double-click it or type
./Joplin-1.0.105-x86_64.AppImage
in a terminal.
#5 2018-09-16 12:11
danielson
Thank you Dai_trying!
Double checked downloaded file and it has exact match in name but this is 1st error message:
chmod: cannot access 'Joplin-1.0.105-x86_64.AppImage': No such file or directory
Did add sudo too.
#6 2018-09-16 12:25
danielson
Gave it (file) "permission".
Sorry for being such a twit!
#7 2018-09-16 12:33
danielson
Yay! i did it!
Sync is on and working!
Thank you Dai_trying for giving that cue! smile
#8 2018-09-16 12:45
You are welcome smile
