#1 2018-11-15 15:39
Andresser17
Geany compiles but does not run the program
I get this error:
Konsole is unable to open a PTY (pseudo teletype). It is likely that this is due to an incorrect configuration of the PTY devices. Konsole needs to have read/write access to the PTY devices.
#2 2018-11-20 17:26
Re: Geany compiles but does not run the program
Please specify, what way did you compile Geany ?
We have successfully tested Geany compilation the standard Debian way:
$ sudo apt-get build-dep geany
$ apt-get -b source geany
Compiled Geany binary launched and worked fine here.
#3 2024-01-28 06:10
david_siburian
I have the same problem too. When I tried to compile a java source file with geany, it displays the same error too.
FYI, I'm using Q4OS Trinity 32 bit with openjdk 17.0.9 in my system.
#4 2024-01-28 10:21
@david_siburian, @Andresser17
Please post more detailed info, so we could reproduce the issue. How did you proceed exactly ?
